Beautiful weather finally in Tennessee and I'm back to seriously working on the 50 Champion. Unfortunately I didn't read far enough in the shop manual before embarking on my latest goof. Instead of taking off the distributor and starter in order to try to pry the flywheel and loosen the engine after its winter Marvel Mystery Oil treatment, I decided it would be easier to take out the radiator and fan blade so I had room to use the breaker bar I borrowed from my dad on the crankcase bolt. Yep, now I have the radiator loose and wedged kadywompass against the fan blade which has one bolt still holding it on. HA! Drat! Guess my question is can I take the bullet nose off and pull the radiator out from the front or will that only make matters worse? Quit for the day when I stabbed myself with the screwdriver trying to turn the set screw on the hood release assembly.
She says "It's all coming apart eventually"
Cabrina Dieters
Murfreesboro TN
1950 Champion Starlight Coupe
Cabrina Dieters
Murfreesboro TN
