Cruising Speed
  • Cruising Speed
    Does anyone know what constant rpms is safe for a 289. I have an automatic with 373 gears (I think) and at 65-70 mph, my rpms are over 3000. Seems like a lot for a long trip.
    63 R2 Avanti
    How much over.....3000? And how far?
    3300/3500 for 165 miles (then the turn around to home, help?
    Actually a shot of about 6 or 8 of those miles was nearer 4000 rpm. Minus stop for the potty and breakfast break.
    As long as the engine's (drivetrain) in decent shape, shouldn't be a problem.
      63 R2 Avanti
      Charlie, I'd recommend that you look for a rear end with 3.54 gears, max. I have 3.54s in my Lark and I love it. Like I was just telling studeclunker, the 3.73 is fine if you have a 3 speed w/OD, but a tad hard on the engine if you have an automatic. A lower ratio, 3.31 or 3.54, will give you much better fuel mileage, a decent pull on the hills and doesn't work the engine unnecessarily. Red line is about 5200 rpm for your engine, running it at 3200-3500 around town should be fine, long trips is where I think that you'll be at a disadvantage.
      While you're running that 3.73, the engine should be able to handle it for some time with no problems, but as it's a mechanical device, common sense tells ya that the more you use it like that, (or put it under heavy stress), the better the chances are that it's gonna wear out/break at shorter intervals. Stude engines are tough, no doubt, but no sense hammering it if you can help it.
      Sonny
      http://RacingStudebakers.com
      Sonny
        I kinda figured it wasn't good for it. I wander if gear benders has a setup for the old BorgWarner tranny. By the way Sonny, I richened the mix on my carb and it helped noticeably.
        63 R2 Avanti
          ALOT of Avantis were built with 3.73 axles and NO O/D. The engines can take it in my opinion. Of course - as with ANYTHING - more use means more wear. Common sense would tell you that. Good tune and good oil and you'll go a long way with that engine. Those higher number axles are FUN away from the stoplight - but they aren't much for delivering mileage. That's where the flexibility of OVERDRIVE delivers an edge![:0]
          I'm with Sonny as far as the 3.54 ratio goes. It's the best stock compromise for performance and economy behind a non-OD tranny
