And am AMAZED at how well it turned out. I tried a test area on a junk Lark fender. I have to admit I rushed things a bit just to see what the results might be. I bought a litre of Tremclad black (apparently same as Rustoleum in the U.S) and some mineral spirits. I bought a bunch of high density foam rollers at the doller store. I poured a bit of the paint into a measuring cup and added about 25 percent mineral spirits and stirred. I poured it into a small roller tray and applied. You get tons of bubbles but they pop with a light blow). I waited about 5 minutes and rolled over my work again with the roller without any more paint added. The next day I added a second coat- same method. I sanded with 500 grit wet sandpaper and did another two coats. I sanded with the 500 again and added another two coats. After 6 coats I sanded with 1000 grit and polished with Turtle Wax polish and my orbital buffer. I kid you not the paint looked FACTORY (actually better as there was no orange peel at all). Perfectly smooth. If I had taken the time to do a perfect prep job on the fender, and bought better rollers, applied a couple more coats and perhaps used 800 grit between coats and splurged on a wool buffing wheel I think the results would be VERY hard to distinguish from a high quality single stage paint job. I'd take photos but my digital camera doesn't have the resolution to truly show how well it turned out. It is also extremely hard and would not scratch with my fingernail. The mineral spirits allow the paint to harden quicker. If I continue with my 63 resto, I am going to paint the trunklid with this method since I have an NOS spare as a backup. If I am as pleased with the results as I was with my test piece, I'll continue and do each panel separately. Some guys on the Mopar forum where this technique came to light seem to have mixed results with Rustoleum. Even though the mfgr says it is the same as Tremclad, I have my doubts as my results look quite a bit better than some of those pictured.
Todd
63 Lark 2dr Sedan
Todd
63 Lark 2dr Sedan
