dana seal replacement
  • dana seal replacement
    need an answer to how do i reset the bearing preload after replacing the rear seal on a 59 lark 6.also how much torque should be required to move the completed job with a beam type torque wrench.i haven't done this job in many years and would appreciate the help...thank you ..bill m.
    bill mathys
    For a dana 44, you change the pre-load with shims. The torque should be between 10-20 INCH pounds NOT foot pounds. I assume it is similar for the lighter axle you have.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
      welcome dollar bill
      I think bill is talking about about the oil seal on the pinion shaft, correct torque is 150 pounds.
      64 is talking about per loading the bearings on the carrier.
      JOE
      1959 HARDTOP R2 4speed
      1960 conv R2 auto
      SDC member since 1972
      1960 conv R2 auto
      http://i237.photobucket.com/albums/ff21/59r2/DSC01514-3.jpg
        If you didn't change anything other than the seal you shouldn't need to reset pre-load on the pinion bearing. Just put the yoke back and torque the nut to 150 lbs.
        ErnieR
        R2 R5388 @ Macungie 2006________________ 1988 "Beater" Avanti
