Hawk deck lid differences
  • Hawk deck lid differences
    I know the '59 to '63 Hawk deck lids are basically the same w/ the '62-'63 using the aluminum overlay. The '64 is unique to that year only. However, is the '56 to '58 the same as the '59 to '63 with just the holes for the pot metal script?
    Thanks
    Dan White
    64 R1 GT
    64 R2 GT
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    No.
      Could you be a little less specific?
        From what I now understand the '56 and '64 deck lids are different and unique to those years. However, the '57 to '63 are the same except for the holes for the script used from '57 thru '61. So an earlier lid from '57 through '61 would be OK to use on a '62 or '63 since any holes would be covered by the aluminum overlay.
        Dan White
        64 R1 GT
        64 R2 GT
        Dan White
        64 R1 GT
        64 R2 GT
        58 C Cab
          Yes.[]
          Tom
          '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
            Do any decklids interchange between C-K and sedan?
              I would doubt it.
              Dan White
              64 R1 GT
              64 R2 GT
              Dan White
              64 R1 GT
              64 R2 GT
              58 C Cab
                No.
                  Gary you have a real way with words!
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  58 C Cab
                    The only thing different with the 56 deck lid is the lock location it would bolt right on with no problem same with the 64 for fit, just 64 GT is a smooth back with no ripples, any 53-55 C/K deck lid will also fit on and bolt right on no problem, been there don that...Bob
                    Castro Valley, CA
                    canbstudebakers-
                    Candbstudebakers
                    Castro Valley,
                    California
                      Like Bob said said don that.
                      This is Bob's 62 GT.
                        From what I can tell the 64 hawk trunk lid is also different in that the lock housing is not in the same location as 63 and prior.it would sit out further being that there is no recess in the sheetmetal,so I assume the latch is not the same either? or is the shaft longer?
                        Joseph R. Zeiger
                        Joseph R. Zeiger
                          Lock should be the same. Look at parts book.
                          David L
                          David L
