Hawk deck lid differences
  • 64Avanti
    Lock should be the same. Look at parts book.
    David L
  • 63t-cab
    From what I can tell the 64 hawk trunk lid is also different in that the lock housing is not in the same location as 63 and prior.it would sit out further being that there is no recess in the sheetmetal,so I assume the latch is not the same either? or is the shaft longer?
    Joseph R. Zeiger
  • nibbs53
    Like Bob said said don that.
    This is Bob's 62 GT.
  • candbstudebakers
    The only thing different with the 56 deck lid is the lock location it would bolt right on with no problem same with the 64 for fit, just 64 GT is a smooth back with no ripples, any 53-55 C/K deck lid will also fit on and bolt right on no problem, been there don that...Bob
    Castro Valley, CA
    canbstudebakers-
  • Dan White
    Gary you have a real way with words!
    Dan White
    64 R1 GT
    64 R2 GT
  • studegary
    quote:Originally posted by buddymander
    Do any decklids interchange between C-K and sedan?
    No.
  • Dan White
    I would doubt it.
    Dan White
    64 R1 GT
    64 R2 GT
  • buddymander
  • sbca96
    Yes.[]
    Tom
    '63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
  • Dan White
    From what I now understand the '56 and '64 deck lids are different and unique to those years. However, the '57 to '63 are the same except for the holes for the script used from '57 thru '61. So an earlier lid from '57 through '61 would be OK to use on a '62 or '63 since any holes would be covered by the aluminum overlay.
    Dan White
    64 R1 GT
    64 R2 GT
  • buddymander
    Could you be a little less specific?
  • studegary
    No.
  • Dan White
    started a topic Hawk deck lid differences
    I know the '59 to '63 Hawk deck lids are basically the same w/ the '62-'63 using the aluminum overlay. The '64 is unique to that year only. However, is the '56 to '58 the same as the '59 to '63 with just the holes for the pot metal script?
    Thanks
    Dan White
    64 R1 GT
    64 R2 GT
