Anyone know if NAPA has a pressure brake switch that is close to ours? 1960 Lark.
1960 Brake Switch
Dave, you might give NAPA a call in the morning & see if their MPE SL 134 SB brake light switch is for your car. My guess it is. Only $6.29 according to their website. Hope this helps.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
I've had problems with the pressure type brake light switches failing, especially in the cars that are using silicone brake fluid. My guess is that your switch is failing and not your wiring. NAPA SL 134 or Standard Motor Parts SLS 27 switches are readily available at the bigger parts suppliers. There is a possibility that the contacts in the directional signal switch are worn and that could also cause your brake lights to become intermittent. Bud
Thanks, Bud. The switch was new two years ago, so it's odd. I got the premium NAPA switch they offered for just under nine bucks, instead of the six dollar version. I also bought a pack of plug ends. They are close to the stock ones on the original harness, but who cares. I need brake lights. I'll get them all on after work. I'm interested in what was the problem. I do have silicone dot 3 in the system now.
Wiring Harnesses, Electric Fan Controls, Accessories, Grounding, Lighting, Switches, Fuel Injection Harnesses, Wiring Aids and More!
...plus it's a lower pressure switch and your brake lights come on sooner.
Bellingham, WA
Bellingham, WA
Thanks Dick. Did you have one in the Ute? When I buy it I want to make sure the brake lights work for ten years...
Bellingham, WA
Bellingham, WA
Got the new switch in tonight. Actually had a 1/2" drive socket that worked under the control arm perfectly. New plug connectors and a new 15amp fuse..good to go. I misspoke earlier; it's synthetic Dot 3 that I'm using, not silicone. Thanks everyone. I'm going to check out that Harley part tip. Gotta be cheaper than buying the Kart Hauler to get a guaranteed switch.
