I need some opinions here please. I have a 54 champ coupe that I got from my father. He has owned the car since 1958. In the early 60's he removed the 6 and put a Stude v-8 and 3spd OD. In the 70's he removed the Stude v-8 and put in a mild chev 283/350turbo automatic. All these years the car has been running the original 4.56 Dana 27 with no failures with the original 2pce drive shaft. I have decided not to push my luck with the strength and age of the Dana 27...after all, something is going to break the way I drive the car, plus the 4:56 gearing really gets tiresome without the overdrive, plus I want a narrower rear track so I can put wider wheels on without the tires rubbing the fenders. Right now the stock driveshaft has a horrible vibration if you accelerate hard from a standstill to about 15mph, then it goes away. After talking to my father, he thinks he never got the geometry right with the center bearing. He figures I should remove the 2 piece driveshaft and replace it with a one piece unit. After doing a search on this forum I get the feeling that I should stay with a 2pce unit if the car came with it, yet I wonder why studebaker changed to a 1 piece driveshaft in later years....seems to me that simpler is better. Needless to say, I have no problems straying from stock, and since I am installing a 3.42 : 1 gm 10bolt rearend I will have to do some sort of CASO driveshaft mods.
1. Should I go two piece driveshaft or 1 piece?
2. If I stick with the 2pce design, is the original slip joint/center bearing from the champion the same size and stength as a commander setup?
3. How much power can the original studebaker 2 piece driveshaft take?
I really don't know which way to go here, so your opinions are greatly valued!
54 Champ C5 Hamilton car. Stock...no way! A Stude hotrod since 1960. In my family since 1958.
