The original post got archived and its apparently impossible to take
from archive. It can not be edited while archived, and my pictures
are in a new location since posting.
Originally Posted - 07/19/2006
I got a set of front brake hubs from a guy who had recently upgraded to
Turner disc brakes from his tired 4 wheel stock drums. I pressed the old
drums off the hubs, and then trial fitted the stock hub into the 13" Cobra
rotor, and it fit perfectly - that was a BIG relief! :
The next step was to press out the old studs :
Here is the studless hub :
Did you know that the factory studs have NO knurl?? No wonder they tend
to strip out so easy with an impact gun!
They looked SOOO ugly, I scraped them with a screw driver, and the took
them to work and used the wire wheel :
Thats all for now .. I had to order the new wheel bearings, seals, caps, and
also make a tool to pound out the old races. The caps I got from Pepboys
in the Help! section, but the part that slips into the hub was too long, so it
would not sit flush, hub against the crimped shoulder. I also bought the 10
Dodge wheel studs mentioned in my original article, and drilled the hub for
the interference fit for the knurl. I took two of the old bearing races, one
of the inners, & one of the outers, and had the machine shop at my work
cut a slot through one side with the chop saw. This will allow me to use as
an installer, so I dont risk damaging the new race with an out-of-control
chisel tip! I went to buy a bearing race installer kit from the local Harbor
Freight, but they were sold out! I will update this thread as I go.
Enjoy!
Tom
'63 Avanti, zinc plated drilled & slotted 03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, soon: TKO 5-spd, Ported heads w/SST full flow valves, 'R3' 276 cam, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires
Enjoy!
Tom
