Tight enough?
It's hard to tell from the picture, but that "looks" like an elastic lock but. If it is, is the shaft sticking thru the elastic portion by a couple of threads?
As far as being tight enough, what did you torque it to?Paul
Winston-Salem, NC
http://partsforsale.studebakerskytop.com/
A "LOT OF MUSCLE", means very little if you used a short wrench !!! OR, it "could" mean you have too much torque, if you used a 3ft. long bar !!
"Tight" wise...check..."the Stude book" for the torque value required.
Nylock nut wise, as r1 says, the threaded shaft NEEDS to be "fully"...engaged into the nylon, or else the locking effect is useless. Two threads minimum for full safety.
You CAN buy shorter Nylock nuts to gain the required thread engagement, if the proper torque doesn't do the trick.
- Likes 1
There are several variables at work, play, here? Is the gear box original, or something modified you installed? Is the pitman arm original, or something else? It could be on as tight as the taper will allow it to move up the splines? If all of this is original, check the torque value in the shop manual and dis the nylon nut.
BoBo
- Likes 1
Isn't the sector shaft spline which the pitman arm bolts to, tapered? Too much 'tight' will split it...64 GT Hawk (K7)
1970 Avanti (R3)
- Likes 1
Yes, I believe those are tapper fit. Could be wrong though, am no expert. If so, I don't think it needs to be super tight, just needs to be nice and snug and the nut not backing off. You definitely do not want that nut coming off while you are driving, otherwise you will likely find yourself in a world of serious uncontrollable problems real fast. I'd definitely make sure the lock nut has 100%+ coverage on the threads if nothing else. Maybe take that washer out if you need more depth to catch more threads. Or if that is a lock washer, maybe add thread loctite as mentioned and should be good. And check it for a while after you start driving it to make sure the nut is staying put, not coming loose.Last edited by M-Webb; 04-24-2025, 09:25 PM.
I had my car for a year or so, daily driver. I drove 250 miles to visit Bensherb. He went over my car with me, tips and tricks stuff... when he noticed there was no nut holding the Pitman arm on! Scary stuff.
I used a thinner washer, loc tight, and a little more effort... so I feel confident now.
I haven't driven my car since I installed Toyota EPS, T5 transmission, new radiator and hoses, battery in trunk, so I will definitely check everything over after a short drive, then a hundred miles later.
Rafe
Rafe
We did dig up a nut from my junk and put one on before you drove back home!
Rafe
At 78 really tight isn't as tight as it used to be, but twisted off bolts are more infrequent. Use a drop or two of blue thread locker and a torque wrench. I have a card with torque recommendations for various bolt sizes and grades. It is good to have one. Those nylon insert locknuts are chinese and aren't the greatest. Don't re-use them and steel ones are some better. Castle nuts and cotter pin is best. (Isn't that the way they came?)
- Likes 1
