1960 Hawk - 289 - Automatic
I am going over the park braking system and am wondering if the 1960 Hawks came with the guide brackets highlighted in blue on the photo of the Chassis Catalog, posted herein.
The illustration numbers / part numbers are:
I went under the vehicle and did not see these guides or their likely mounting points. I know the Chassis Catalog illustration is indicates “Typical Parking Brake”… was the Hawk “typical”? Does the 1960 Hawk not use these?
Going under the car I can see I have both of the rearward brackets (passenger side circled in red in attached photo). Illustration number / part number:
Photos attached are:
Vehicle’s Background:
The car underwent a restoration from 2003-2006. Restoration shop went bankrupt prior to 100% completion. Owner died in 2008. Son had garaged until 2022. Another owner bought and never got around to it. I now own it and trying to get it on the road.
Vehicle has/had dual muffler / dual exhaust. Exhaust system was replaced, per original owners records, I do not know if it was with OEM or aftermarket. I removed passenger side all the way to the most forward portion of pipe as it was not supported with mounts from beneath the firewall area back. The weight of the system was primarily resting on the parking brake cable under it… the white rope you see in the photo was not supporting the muffler at all.
Once the passenger side exhaust unit is reinstalled it may cause an additional clearance issue. Not sure I want that passenger side exhaust routed as it was… hangs quite low and seems like an after though… but that can be dealt with at a later time.
- 1110-26 / 532668
- 1110-27 / 532669
- 1110-28 / 1549481
- 1110-29 / 1549482
- Chassis Catalog - Yellow highlighter indicates components that I have. Blue highlighter indicates missing components.
- Photo showing rearward bracket, on passenger side, circled in red.
- Photo showing where parking brake cable contacts exhaust pipe if pulled taught, as is now - without forward guide bracket.
