Greetings all. My R-2 Avanti has been running well until yesterday. While I hadn’t run it for almost a month due to the weather, snow, salt, etc. it started right up after cranking for about 5 seconds. Then I had to keep my foot on the gas or it would stall. I thought once it got to operating temperature it would smooth out, but after almost 15 minutes I let off the gas to check things out and it just stumbled and quit. When I got out I was surprised to see that it leaked a significant amount of gas! There was a pool of gas in the cavity on the top of the intake manifold between the back side of the carburetor and the vacuum tee pipe fitting. There was so much gas that it ran down to a cavity on the back side of the block under the distributor. There was also gas in the chrome valley tray under the carburetor. I took the bonnet off the top of the carburetor and the secondary butterflies were wet which might explain why it was running so ruff in addition to leaking gas. Since I could not watch exactly were the gas was leaking when the engine was running, based on the residue I could see, my guess is that most of it was coming from the Air Horn Gasket in-between the Air Horn Assembly and the bottom part of the carburetor. There was also a lot of residue where the accelerator pump plunger comes out of the top of the carburetor, but there was no pool of gas in the front area like there was on the back side.
I guess I’m looking at a total carburetor rebuild based on the fact that it is not only leaking gas like a sieve out of various areas but also running ruff. I’ve heard that carburetor is tricky to rebuild correctly so it is beyond anything I want to tackle as a novice. I live in Cincinnati, Ohio and was looking for someone experienced at rebuilding the Carter AFB Carburetor for a R-2 Avanti. I’d like to take the carburetor to someone in the area if possible, but if I have to ship it somewhere to get it rebuilt correctly so be it. I just want the job done right.
Thanks in advance for any help or suggestions on where to get this carburetor rebuilt.
HB63A2
HB63A2
