53 Champion clock wiring
  • Electrical: 53 Champion clock wiring
    Will my 6 volt clock work on a 12 volt conversion?
    Only if you run the Power Wire through a Volt-A-Drop unit to reduce the Voltage to 6 Volts.
    I don't know if you will have to isolate it from ground, due to it being designed for a Positive Ground System and running it on a negative ground 12 Volt System.
    That depends on the type of voltage drop unit you use I believe.
      If this is an original al clock it should be ok. If its been converted to electronic probably not. This has been covered in the forum before if you can find it. As usual there are a variety of opinions expressed.
      American iron, real old school
      With two tone paint, it sure is cool
      Its got 8 cylinders and uses them all
      With an overdrive that just won't stall
      With a 4 barrel carb and dual exhausts
      With 4.23 gears it can really get lost
      Its got safety belts and I ain't scared
      The brakes are good and the tires are fair.
      Tried to sell her, but got no taker
      I"ll just keep driving my Studebaker
      • StudeRich
        StudeRich commented
        Editing a comment
        We know that his Car is Now 12 Volt Negative Ground, so HOW is that possible?
        The smoke will likely get out of the Motor of a Borg Clock !
      If it's still a stock remontoire movement, yeah, it will probably work for a period of time on 12 volts since the winding solenoid is only engaged for short bursts, and is not polarity sensitive. Double voltage is pretty spicy, so point life is going to suffer and the works are going to take a beating as the solenoid plunger is fired out at warp speed. Since clocks are usually robust enough to make it a few years between servicings if the stars align and you never let the battery run down and don't expose it to extreme heat or cold, you should get a few months out of the overclocked one before something lets go.
      Whirling dervish of misinformation.
        My 12 volt conversion will be negative ground. As I will disconnect the battery between car shows and driving for pleasure, the clock will always not have the correct time. So, I think I'll just leave it disconnected. Thank for all the replays.
