Rebuilt Saginaw power steering pump leaking through”weep hole”
  • Steering: Rebuilt Saginaw power steering pump leaking through”weep hole”
    Hi,
    ran my ‘57 289 w/ Saginaw power steering for the first extended time yesterday (20 min breakin run) and was very surprised to find a trickle of power steering fluid running down from the pump bracket. No leaks anywhere on the pump body, but when I removed it, could see it is apparently coming from the little “weep hole” behind the bearing.
    I cleaned it off, ran it again for a while at idle, and there was a little more laying in that pump mount ‘valley’.
    I rebuilt it a couple years ago, complete Phil Harris kit, hard to believe the seal in front of the front bearing could be bad.
    Bearing itself and all gasketed joints are dry as a bone….
    Any other possibilities, before I call him and order a new seal?
    Thanks!
    Barry
    (3rd photo is simply the little pool of oil in the pump mount…)
ID:	2020279 Click image for larger version
ID:	2020280 Click image for larger version
ID:	2020281 Click image for larger version
    I don't have an answer for you, but I'll bump this back up to the top of the list for another look see by everyone.
      Thanks Dan; update since I posted; removed the seal, as anticipated, nothing wrong with it…. Examined the seal area of the shaft VERY closely, thought I found the problem with the pitting near the edge…. But from faint wear line (from lip) and vernier measurements, seems lip rides JUST inside all this.
      BUT, just in case, I made a spacer to move the lip-seal a little farther in so there is no doubt. (There is plenty of space between the seal and bearing) Click image for larger version
ID:	2021022 Click image for larger version
ID:	2021021 Click image for larger version
      Also, planning to put some Permatex#2 around the seal in case it was weeping around the perimeter.
      Phil has a new seal on the way; I’m sure it will be fine, just won’t know why it leaked the first time….
      Sure wonder why they have a “weep hole” there, it’s not a water pump! Expecting the seal to leak? (And with the sealed bearing there, would it matter?)
