v8 carter fuel pump glass bowl
  • Fuel System: v8 carter fuel pump glass bowl
    hi,
    going to throw on a new carby soon and refurbish the fuel pump with an ethanol kit.
    I need a model number please, and does anyone know what is the psi output?
Name:	Carter Fuel Pump V-8.jpg
    The model number should be stamped into the edge of the mounting flange.
    Sorry I can't help you with the output pressure.
    Paul
    Winston-Salem, NC
    Check out my YouTube channel here: https://www.youtube.com/user/r1lark
    http://partsforsale.studebakerskytop.com/
      Fuel pressure should be 3 1/2 to 5 PSI.
      Studebaker driver since 1971
      59 Lark
      59 4X4
      62 E45
      64 E15
      64 E35
        The original pump would be a Carter m2573S
        59 Lark
        59 4X4
        62 E45
        64 E15
        64 E35
        • 1960Hawk
          1960Hawk commented
          Editing a comment
          thanks, can order kit now
        Qs...anyone
        would this be sufficient for an edelbrock avs2 500cfm ?
        was reading somewhere 6psi is the sweet spot.
        the original carter 4barrels where smaller ?
        Does the ethanol rebuild kit give it slightly more psi?
        I do have an electric fuel pump installed, but only for priming.
          Call Dave he is easy to talk with and knows all about those pumps...he has the parts and the knowledge....
          Dave & Janet Thibeault
          13 Nick Lane
          Maynard, MA 01754 978-897-3158​
            That pressure is Fine, the Volume is more important though.
            If operated above 4000 RPM often, a Carter Super Pump is recommended as on R1 and R2 Avantis.
              thanks, good info for others searching
              ....so for your street driving / cruising and casual low performance street drag, it will be fine.
              will using a larger fuel line from pump to carby help increase volume?
              • 1960Hawk
                1960Hawk commented
                Editing a comment
                forget the larger fuel line Q....
                larger line = less psi
                its just a run about street car and not worth stuffing around :0
              Originally posted by 1960Hawk View Post
              Qs...anyone
              Hi 60,
              Welcome to the forum. Are you in South Africa or South America, or Australia?
              Most Studebakers in the 50's and 60's ran 450 to 600cfm carbs. If you have a 2,500cfm you will drown the poor V8 and have very poor performance in my opinion. I had a 1955 V8 that had a Carter but I don't remember back to 1968 what the cfm was but with the overdrive the car ran great up to 120mph@4,500 rpm. That was pretty much the limit due to valve float above 4,500. The mid 60's performance V8's had strong valve springs that give you higher rpms.
              My 57 Golden Hawk does not the supercharger hooked up so it is running a standard fuel pump. The GH pump is different in that is has a pressure line running from the blower to get more psi when the blower is engaged. The car runs great and from a start, with the 3 speed and overdrive and a 3.92 TT dif has not problem leaving other cars behind at a stop light start.
              Best regards
              • 1960Hawk
                1960Hawk commented
                Editing a comment
                hi sir....thank you.
                I don't have twin 500 carbs
                the 2 is from edelbrock AVS2.
                swapping out the holley 600 for it
                not going to play around too much with the motor, because it already goes like a little rocket :0
              • Skip Lackie
                Skip Lackie commented
                Editing a comment
                Bob-
                Since 1960Hawk didn't answer your first question, I will. Adelaide is in the state of South Australia.
              finally got a to start on updating the carby....
              pump overhaul, ----glass bowl filter.
              my kit came with a brass filter and different spring.
              And that spring is perfect for holding the brass filter in the glass bowl.
              Would the mesh by itself be better flow?
              or just stick with the older type filter?
              It is possible to use both filters with the old spring
                  Just be sure it all clears the steering.
                    just some info from this you-tuber.
                    been watching a lot of his uploads, smart young man
