Over the years, I have bled hydraulic brakes on many different vehicles but never have done it on my Studebaker. I'm embarrassed to say that I attempted, but the small bleeder nipple stymies me. Even with an offset 1/4 inch wrench, there's not enough length left in the nipple to attach a bleeder hose. Looking for tips and tricks that have worked for others. Please share your method of attaching a bleeder hose while wrenching the fitting open and close. Thanks!
1950 Champion Brake Bleeding Tips needed
There is no need to wrench the bleeder open and closed. Your master cylinder has a check valve which should keep it from drawing back as you let off the pedal. So just get a length of of small hose and submerge one end of it in a little brake fluid in some old bottle. Loosen the bleeder, stick on the hose, and pump the pedal til you don't get any bubbles. I like to give the pedal a pretty vigorous down stroke to help flush out the cylinder, but return the pedal slowly so the master cyl. has a chance to suck in its new charge. If the brakes have been sitting for a long time it is not a bad idea to take the bleeder screw out completely and clean it before you start.
Ross is right, I used to do it that way. Then I put a set of Speed Bleeders on my car, makes it even simpler. I don't even have to be under the car. Speed Bleeder Main Page
