For those of you who've patiently endured my leaking/weeping brakes as I learned to flare brake lines and fit a dual-cylinder M/C to my 57 Golden Hawk project, after four years, I've finally got leak free lines & M/C!
(a 2nd gratis M/C from Jim Turner did the trick. Best guess, my "learning to flare" and repeated cranking on the fittings ruined the first M/C's nipples??)
SO, I was finally motivated to MOVE ON, and was going to button up the wheels and bearings tonight; pulled off the drums just to remeasure the spindle diameter, as I was debating peening or Loctite for inner bearings. Confirmed only 0.002" under so planning to let the spindles be.
HOWEVER, I noticed a 'drip' on the edge of one of the wheel-cylinder rubber boots. REALLY!!??
(For everyone else, my Hawk project is still just a chassis; the body still on a cart, so the only "brake action" these cylinders have seen is me manually pushing the brake pedal as I chased down my brake fittings & M/C connection weeps, and re-bled multiple times.. 2019-2023!).
Pulled off the rubber boots on all four cylinders, and all but one had some DOT5 sitting in them. ONE side of one cylinder completely dry....
I wiped them out really clean, then did some more pumping of the pedal (w/ drums on of course). Repeated this cycle three times (about 100 pedal pumps in between), and still have ‘wet’ pistons each time. 2nd photo and shop rag shows this “new fluid”. Not a heck of a lot, but seems there shouldn't be ANY?
In frustration, I gave up for the night to bounce it off you all.
Important note (may be the problem): I purchased the whole set of cylinders way back in 2011 with a bunch of parts I "knew I'd need ". I didn't actually assemble them to the car until 2017, and noticed there was some very slight corrosion starting inside the bores, and on the pistons. I easily cleaned this off with Scotchbrite (see before and after), and had all parts spick and span for re-assembly and mounting on the car (in 2017). Since then, as mentioned, only manual pumping of the brake pedal during these last four years of brake-misery.
Only three things I can think of to explain the presence of DOT5 outside the pistons WHILE rebuilding the car:
1) Scotchbrite isn’t the way to clean that slight corrosion, and the seals are leaking because of it?? And I need to replace all four cylinders. Again
(if Scothbrite too aggressive, how DO you clean them then?)
2) Maybe there is enough residual DOT5 from assembly to still be showing up? (I lathered everything before putting it all together) that is still oozing off the pistons. (But, ONE piston is totally dry. How to explain that...).
3) these "new" cylinders have cheap seals and with slippery DOT5, just not a happy marriage?
I’m learning patience with this project.. but replacing unused new parts, with 2nd sets of new parts, is getting old. (have a torn 'brand-new' bearing seal in one wheel too. Sigh.)
Thoughts?
Thanks guys!
Barry
Thoughts?
Thanks guys!
Barry
