No problem! I hope you guys like a mystery: the generator is charging beautifully, and I have been over the past few days monitoring the voltage of the battery. When I left on my test drive today it was 6.33. I drove it for 20 minutes at a nice rate of speed 40 miles, an hour, made a U-turn headed back home, turned into the neighborhood, and the car died out. Pull the emergency brake, put it in neutral press to start a button, and the car would barely turn over much less start. After an adventure getting it back home. The first thing I did was put my voltmeter back on the battery and see if it was dead and lo and behold. The voltage of the battery during this trip increased from 6.33 to 6.42. But the car at least right now will not crank, it just barely turns over. I must have the most problems out of everyone on this menu. And it was running beautifully. Didn't miss a lick didn't die out one time, I'm really puzzled. It's a problem for tomorrow. Thanks in advance for any ideas as usual all the best, Roger.
PS I did install a ground wire from a small screw on the casing of the generator and grounded it to the block at the water pump just a side. FYI note see pic and the green wire. I think this has nothing to do with anything.
