62 Studebaker Lark V8 Conversion
As 52 said. You gotta upgrade the rear end to a Dana 44, the rear end for a v-8 Studebaker. The Dana 27 that comes with the 6 cyl just will not handle the torque of the v-8, unless you are really going to baby this thing. Also, get some v-8 brakes. Needs this stuff, bad.
nice simple mounts. I think I'm going to use that type in my 302/40 Nash
Nice looking job glad you use a real 289 even even if its the later Ford one as the Studebaker 289 came first The Ford engine has a lot of after market parts almost as many as the Chevy. Looks like it was worth the time and effort.
quote:Originally posted by buddymander
nice job. looks like a stock oil filter. I bet that SBF weighs the same as the six did. What trans are you using? Those AOD's are a dime a dozen and would be great with the overdrive and low first gear. 85 to 94, I'm pretty sure are the best years. 95 went to computer controlled electric solenoids.
Did you upgrade the rear end?
1952 Champion Starlight, 1962 Daytona, both w/overdrive.Searcy,Arkansas
"I may be lazy, but I'm not shiftless."
I know it has been a while since I posted this but thought I would let you know how it was going. I got the engine installed, exhaust on, pretty much just a couple days work and drive line being cut from getting it running. Still have to rebuild the carb and exchange the electronic distributor I got for a new one (the one I bought was giving me no spark).
I have been working on this since I was 13 so I am pretty excited (my grandfather gave the car to me and a lot of work has been put into it). I am 22 now and I am excited to take make some brackets in the back seat to mount the car seat to so that we can go on rides together.
I had to flip the original mounts around and make this bracket. With the little help of an after market oil filter the 289 fit!
Now just to put the front end back on, a little body work while I am at it and then off for one last paint job!
Kurt,sent you a private email.Please let me know if you do not receive it..Thanks.
Jeez Guys, I was able to say it right after Jack said they were welded, without all the SHOUTING!
I tried to shoot him down EASY! Lol!
QUOTE: "a very nice factory cast iron engine mount bracket that excepts a GM Engine Mount now available in aluminum from most of us Studebaker Vendors at studebakervendors.com to secure the front of the SBC engine to the front crossmember [u]by simply bolting it in!
</u>
And if you can find a used '65-'66 rear tubular crossmember, [u]it is a "Bolt-in"</u>, after adding a short ext. with only minor driveshaft, shifter & wiring issues with the right hand starter on the GM engine and left hand batt. on the Lark, all very easy stuff, but will add to the cost."
Ease of conversion;
1) Another 6 cylinder
2) Studebaker V8
3) Chevrolet Small Block
4) Everything else...
Tom - Mulberry, FL
quote:Originally posted by PackardV8
Hey Jack,
Didnt used to be so easy to change fonts, type size etc
Used to have to manually separate the codes for the different effects.
Like thisThen I finally figured out to highlight the text first.
The stock Chevybaker engine frame mounts bolt onto the frame, they are not welded!quote:Finding the '65-66 V8 mounts and [u]welding</u> them in as about as difficult as the easy-to-fab SBF mounts. In the engine-swapping universe, either engine into a Lark is as easy as it can get.
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
59 Lark
etc
Guest repliedquote:Originally posted by buddymander
WE all know what a studebaker frame looks like. We needed to see the frame with the engine dropped in. But I have used the SBF in several frames, but not studebaker, so I'm familiar with their particular dimensions to a degree. I just recently put one in a 40 Nash. I used an aerostar front suspension and rack so I know about the oil filter interference. The 89 and up sbf used an oil filter relocater in the t-bird. My 88 cougar motor has rear sump; they're pretty common anymore. I just wonder how close the oil pump bump on the front of the pan will come to the bellcrank. That's my only concern. And I would try a short filter to clear the steering link before I used a relocater. There's going to be quite a bit of room there. Use one of fords AOD transmissions in it to make up for the low rear gear ratio. Nice car.
Bill, Many Fords and one great Stude!
quote:Originally posted by whacker
That is a nice looking car! Have you thought about putting another Stude six into it? You should be able to get one pretty cheap. and putting it in would be a weekend job.
Dick Steinkamp
Bellingham, WA
[IMG]
[/IMG]
