Has anybody converted vacuum wipers to electric (6V) on a '47 Commander?
'47 Stude vacuum to electric wipers
Studebaker made electric wipers a no cost option in 1951, so it's certainly doable. It's just making the determination as to what works. As an aside electric wipers were used as an option on some pre-war Studebakers, so it was nothing new.
- Likes 1
Use the wipers, and linkages off a 52. They are a direct bolt in, and do away with the cables.Bez Auto Alchemy
- Likes 2
Originally posted by bezhawk View PostUse the wipers, and linkages off a 52. They are a direct bolt in, and do away with the cables.
There used to be a company that made electric wiper motors that bolted on to the spot where the vacuum motor mounted. I did that with a 1958 Jeep station wagon once.Last edited by RadioRoy; 07-29-2022, 11:35 AM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
- Likes 1
Newport engineering makes a bolt in motor that replaces the vacuum wiper motor using the stock linkage. https://newportwipers.com/product-ca...rs/studebaker/
There is an additional option, in the day there was an electric vacuum pump that ran through the vacuum circuit and when the vacuum dropped off the motor started and recreated the vacuum so the wipers would not stop going up a hill.3 Photos
Thinking out loud here: would it be possible to wire in a rheostat in the electric wiring circuit to have variable speed wipers? I think it would be nice to be able to vary the speed of the blades depending on the condition of the weather. Not to go as far as Ford did with the intermittent wiper system but be able to control how fast the blades operate might be nice.
We have our monsoon now and it can vary between slight rain and steady rain so having more than two speeds might be nice. It is also nice to have the rain in Arizona with cooler temperatures
Bob Miles
It rained 3 inches yesterday, 3 inches between the drops
The problem with rheostats and wiper motors is that the load on the motor varies over the span of the sweep, and also if the windshield is wet, or dry, or coated with bug guts. As the load on the motor changes, so does the voltage drop across the rheostat, and hence the speed can vary a lot. I think a toe button mounted on the floor, and wired in parallel with the wipers' park switch would be the way to go. Give the toe button a slight tap' you get one sweep. Hold it down, and the wipers run until you release it. My Suburbans do that if you twist the wiper control backwards; one sweep per twist.Gord Richmond, within Weasel range of the Alberta Badlands
- Likes 1
