I have been told by a professional mechanic that my Hawk has 1963 T-10 Corvette Transmission. It has been in it ever since I bought it in 1979. I have run it hard over the years and never have ever had a problem with it. My mechanic says it is a almost indestructable transmission. I can verify that because I have run it hard over the past 40 plus years with no problems what so ever. Does anyone have information on this transmission they can share with me?
T-10 Corvette Transmision in my Hawk
Bill, not knowing exactly what information you are looking for makes it hard. But first, there is quite a long section in the Studebaker '59-'64 Shop Manual on the T10. Also, a simple Google Search for "borg warner t10 transmission" or similar brings up a huge amout of information.Paul
Winston-Salem, NC
Visit The Studebaker Skytop Registry website at:
Check out my YouTube channel here:
I also have a gm t10 out of a 63 or 64 studebaker station wagon. My question is, did studebaker use these instead of the regular t10.
it is stamped GM 1961 rite on the case, it is bigger and heavier then the standard t10,I have 2 standard ones to compare to.
The GM one is now in my 56 pickup behind a 259 .
Originally posted by jetboat View PostI also have a gm t10 out of a 63 or 64 studebaker station wagon. My question is, did studebaker use these instead of the regular t10.
Wanting a 4-speed all-synchromesh transmission for the 1957 Corvette racing program, Chevrolet participated with Borg-Warner in re-engineering the T85 transmission; thus being granted a four-year exclusive use.
In 1961, Studebaker became the second US automaker to offer the T10, using the same case as Chevrolet, but a different input shaft. Mid-1962, Studebaker switched to the same Ford pattern as had been used on the T85.
While a GM or Ford T10 can be used in a Studebaker with the appropriate bell housing, neither is ideal, as the input shaft is an inch too short, requiring a custom pilot bearing.
There are also four different tailshaft lengths. Some of the Ford tailshafts are too long to be use in Avanti and the Lark converts/wagons.
At a glance, some of the AMC T10s can be mistaken for a Ford. However, the case bolt pattern is reversed and not interchangeable.
In the late 1960s, to keep their OEM and aftermarket share of the performance transmission, Borg-Warner developed the "Super T10" with a stronger alloy case and stronger gears.
jack vinesLast edited by PackardV8; 06-30-2022, 07:53 AM.PackardV8
- Likes 4
The GM one is now in my 56 pickup behind a 259 .78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
While the GM 1961 on the case is not conclusive, if it's a date code, it's not for a Muncie first offered in 1963. If you've ever looked at a Borg-Warner T-10 and a Muncie four-speed and gotten them mixed up, it's because the Muncie is a direct descendant of the T-10. GM's goal with the Muncie four-speed was to produce a stronger transmission with better shift feel by employing larger synchro cones.
jack vines
I formerly drag raced T10's behind GM small blocks in the late 60,s. At the time we used to dump the clutch at 5000 RPM and hang on. Ran 450 gears and got through 3 gears in a run. I can attest to the strength of these trans. Only damage I ever did was to strip a counter gear years later in street use. They are indeed hard to hurt.
BobBob
Welland Ontario
60 Lark Convertible
64 Daytona
Agree, for the use for which it was designed, small block V8s, the T10 is perfect.
Once GM, Ford and Mopar began offering high torque 427" and larger big blocks, the T10 could not cope. As previously mentioned all three manufacturers developed different, stronger 4-speeds.
IIRC, Ted Harbit raced the same close-ratio T10 for decades before it finally had some problems.
jack vinesPackardV8
Bill,
If this thread does not go far enough towards answering any question that you may have-use your search box at the top and put in T-10, or some similar description, and you will get all the archival information that the forum has maintained for decades. I did it for a trial run and I believe that I got 23 pages of pertinent information.
