Hi, starting a new thread on my 57 Golden Hawk carb issues. Wondering if anyone knows what the correct fuel-level IN THE BOWL should be?
Quick context; have all-rebuilt chassis/engine/carb etc.., and have been trying to start it up just to confirm "all good" before mounting radiator, Supercharger, and doing the 20min run-in. Had problems starting and running overly-rich, having to manually open the choke to keep it runnign for 20 seconds or so.
-checked my R2 Carter fuel-pump, thinking over-pressuring perhaps; got ~6 psi before the fuel filter/relief, and just under 5psi going into the carb (I have a return line and the 0.040" relief orifice on fuel-filter bulb). Seems in-line with the 57 Shop Manual (fuel-pump pressue supposed to be 5-7psi). So not OVER-pressured....
-Then had carb professionally rebuilt at Daytona Parts, and received it back with their flat-needle seat, and the float adjusted quite a bit lower (maybe 10/32") than the 7/32" in Shop Manual. Daytona explained this as deliberately done for both less-dense unleaded gas, and due to the flat (not a true needle) float shutoff.
(photo below)
Dufus recommended I try running with the carb "open", and see what the float and needle are doing. Did so tonight.
1) was able to start by covering ("choking") the carb with my hand, and barely keep running by raising my hand "just right". Would not run with my hand removed. (seems logical to me, but I've never tried running a car with the top of the carb removed before).
2) measured the fuel level in the bowl; pretty close to 7/8", or a bit less. Maintained this as I fussed with it, running or trying to do so; float seems to be working properly.
Does anyone know what the fuel level SHOULD be, since I can't go by my float setting apparently?
I searched the web, found a Stromberg manual listing the fuel-level from top of the bowl for MANY makes of cars and models of Strombergs. Most were 5/8" or close to that (including WW carbs for other applications; but no information for anything newer than '55, nor Hawks)
Therefore my 7/8" fuel-level (maybe a bit less) seems high, considering my float is already very LOW and fuel-pump pressure is correct. Unless the Hawks /289 did have a higher fuel-level than the apparently typical 5/8"?
I'd like to adjust it best I can while I have it apart, instead of finding out it floods easily when I finally get to driving the car at some point. Also seems "wrong" to be moving that float even FARTHER away from the 7/32" spec....??
Thanks!
Barry
(photo below)
Thanks!
Barry
