1955-64 Champion truck engine experts, need block plate/bellhousing help
  • Transmission / Overdrive: 1955-64 Champion truck engine experts, need block plate/bellhousing help
    A local friend wants to use a '55 185" engine in an earlier truck but has had no luck finding the rear block mounting plate. He says his Parts Manual shows a number change at 1959. I was under the assumption that part was the same '55-64 and all of them mated to the V8 bell housing. Can anyone confirm or clear up what actually works on which years?
    He's really in need of this part, so anyone who can supply same, e-mail, phone or PM me.
    Thanks in advance.
    jack vines
    Dwain Grindinger was kind enough to send me the four-page technical bulletin about using the '55-'58 185"s in earlier Studes.
    Still would like confirmation as to whether the '59-'64 truck rear block plate is the same as the '55-'58 truck.
    jack vines
      jack vines
      Jack, only the 8E (1963 & 1964) engine plate allowed the mating of the V8 bellhousing to the six cylinder. Some taxis used this plate also.
      Paul
      Winston-Salem, NC
      [B][I]Visit The Studebaker Skytop Registry website at: [/I] [URL="http://www.studebakerskytop.com"] www.studebakerskytop.com[/URL]
      Check out my YouTube channel here: [URL]https://www.youtube.com/user/r1lark[/URL][/B]
      [B]Check out my NOS Studebaker parts For Sale here:
      [URL]http://partsforsale.studebakerskytop.com/[/URL][/B]
        Learn something every day.
        Since the T90 was used in most years of trucks, can we assume the reason for using the V8 block plate in '63-'64 was to allow the use of the HD automatic in the Zip Van? Any other thoughts as to why the change?
        jack vines
          jack vines
          Without looking at the parts book for the largest 6 cylinder clutch in '62............maybe to allow a larger clutch/flywheel size in the 8E trucks?
          Paul
          Winston-Salem, NC
            Try Tom Karkewicz. 574-287-583four.
              The part numbers for the rear plate did change in 1959. Two new numbers, 1691972 for Autolite starter, 1691544 for Delco. First number shows for '59 only, the other one through '62. And one more new number for '63-64, 1546534.
              Not sure why the starters would cause need for a change in the plates in '59.
              [I][SIZE=20px][FONT=Comic Sans MS]Restorations by Skip Towne[/FONT][/SIZE][/I]
                Thanks in advance.
                jack vines
                My experience was a 57 185 but the transmission came with it. It was a car engine. So I took my 53 169 truck mounting plate and bolted the two together and drilled the necessary holes in the 169 truck plate to mate up with the 185 block.
                1936 Dictator
                1950 Champion Regal 4 dr parts car
                1953 Commander Regal HT
                1953 2R5 Pickup
                1947 M16 Truck
                1949 2R16 Truck
                1960 Lark VIII Convertible
                1960 Champ 5E7 step side short box
                1962 Champ 7E5 no box
                1962 GT Hawk
                1963 Lark VI 4 dr
                1963 GT Hawk R2
                1964 Daytona Convertible
                1964 Commander Wagonaire
                “America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln​
                  Great info!!
                  Those of us who think the crank main bores were lowered for the longer stroke 185" crankshaft probably would have mistakenly assumed the earlier small-block rear block plate couldn't be modified to fit. Now we know it can.
                  jack vines
                    Innersting; I knew the main’s diameter got bigger but presumed the centers remained the same and that the block became taller.
                      If the centers remained the same, why would there be a different cam/crank gearset?
                      jack vines
                        Didn’t know that; thanks Jack!
                          Yes the block is 3/8" taller I think. Check the difference in stroke on the two and that's how much higher the block is.
                          1936 Dictator
                          1953 2R5 Pickup
                          1947 M16 Truck
                          1949 2R16 Truck
                          1962 GT Hawk
                          1963 Lark VI 4 dr
                          1963 GT Hawk R2
                            A bit of math and geometry is in order; for a 3/8" longer stroke, the piston only goes 3/16" higher in the bore and 3/16" further down at the bottom.
                            jack vines
                              I know that but when you measure from the top of the bellhousing to deck it's 3/8" higher.
                              I have a block here, I will check.
                              1936 Dictator
                              1953 2R5 Pickup
                              1947 M16 Truck
                              1949 2R16 Truck
                              1962 GT Hawk
                              1963 Lark VI 4 dr
                              1963 GT Hawk R2
