any issues to look out for when replacing
brake master cylinder replacement 1950 starlight
Hmmmm. I never bench bleed single master cylinders--it makes for a very messy installation. Worked OK for the last hundred or so I've installed.
Regardless, when you do get it installed on the frame be sure to adjust the pushrod length so that there is a small amount of free play at the pedal; 1/8-1/4 inch would be OK.
Do not forget to use or replace (Preference on replace) the 33/64" and 39/64" Copper Crush Washers on each side of the Brass Banjo Fitting.
I include them with new Master Cylinders.Last edited by StudeRich; 09-22-2021, 01:27 PM.StudeRich
If you can't stand the sight of blood or bruised knuckles wear gloves. Sometimes it is hard to find the copper crush washers but you can heat the old ones red hot and let them cool and they will work fine. It is what I usually do. Damned old age and bad memory won't let me remember what they call the process but a lot of mechanics use it.
Originally posted by E. Davis View PostIf you can't stand the sight of blood or bruised knuckles wear gloves. Sometimes it is hard to find the copper crush washers but you can heat the old ones red hot and let them cool and they will work fine. It is what I usually do. Damned old age and bad memory won't let me remember what they call the process but a lot of mechanics use it.
-Dwight
