anybody running aluminum brake drums?
anybody running aluminum drum brakes?
What I would like to see is aluminum brake rotors with replaceable steel friction surfaces. Combine with aluminum calipers, and you might be able to have disc brake effectiveness with less unsprung weight than stock drums.Gord Richmond, within Weasel range of the Alberta Badlands
- Likes 1
Gary Ash
Dartmouth, Mass.
’41 Commander Land Cruiser
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
Originally posted by t walgamuth View PostI am wondering if any of the places like Summitt offer aluminum brake drums drilled as you need them..?
For cost-no-object-CASOs-need-not-apply, there are carbon fiber ceramic matrix rotors which are amazingly light; only about $1,000 and up each.
jack vinesPackardV8
Running a 60-70 year old suspension design with steel wheels and a solid axle with leaf springs makes worrying about the unsprung weight of your brakes a idea to play with rather than a noticeable improvement to your ride, handling, or performance.
- Likes 1
Unsprung weight makes a huge difference in how your car handles. Modern steel belted radials are much heavier than 6.70X15 bias tires, as are the rims needed to safely carry them. You put those on your Studebaker, and then add 12" ventilated cast iron rotors and the heavy cast iron calipers, and now your poor springs and shocks are trying to control about twice the weight they were designed to do. Of course, your ride quality is going to suffer.Gord Richmond, within Weasel range of the Alberta Badlands
So nobody except Gary Ash is running any aluminum drums? If I could pull off my old drums and slide on a new aluminum one I could maybe save 5# per wheel? That is noticeable to me. I'll call Summit and see what they offer.Diesel loving, autocrossing, Coupe express loving, Grandpa Architect.
Yes, Summit has aluminum brake drums, but only in 9.5" diameter with 4.75" bolt circle. As I mentioned above, it ain't that simple as re-drilling the bolt pattern. Center hole, offset, shoe width, adjuster holes, all have to fit.
Free Shipping - Cardone New Brake Drums with qualifying orders of $109. Shop Brake Drums at Summit Racing.
Did we ever weigh the Studebaker OEM disc brake components and the OEM drum components and compare the two? IIRC, the disc setup was at least the 5# lighter you're looking for.
jack vinesPackardV8
Tom:
Here are some weights on the Indy car:
Brake backing plates and shoes: 12 lbs
Hub: 8 lbs
Aluminum brake drum: 18 lbs
Wire wheel, 18" x 4" rim: 20 lbs
Tire: 6.00/6.50-18: 20 lbs
Spinner: 3 lbs
Total is 81 lbs on the front spindle and knuckle. However, I'm probably way ahead of what was originally on the 1929 President axle. It had 15" drums with 3-shoe rod-operated brakes, wood wheels, and huge rims and tires. The front axle with spindles weighs 92 lbs and each front leaf spring weighs 22 lbs. Rear axle is 175 lbs, 32 lb springs, 24 lb 7.00-18 tires. I only counted half the leaf spring weight as unsprung. With 2 passengers and 10 gallons of gas, I estimated the total weight to be 2700 lbs with 640 lbs of it unsprung. I wonder how that compares to a 1960's Studebaker and a modern car.
Wood wheel with steel hub, brakes, tire, and 15" brake drums from 1929 Studebaker President.
Aluminum 90-fin drum from ca. 1967 Buick Riviera with steel splined hub for wire wheels.Gary Ash
Dartmouth, Mass.
'48 M5
- Likes 1
