What kind of wiring mishap would lead to my left turn signal coming on constant when I turn my instrument lights switch on?
Wiring 1963 GT Hawk
Tags: None
Someone plugged the Turn Signal Bulb Socket into the Hole for the Instrument Light and vice versa! That would be "crossed' in my book.StudeRich
Yes but it illuminates when the instrument panel light switch is turned on, not the parking lights.Originally posted by Lark Hunter View PostI'm presuming you mean the green dash indicator for left turn signal? If it flashes with turn signal, but illuminates steady when parking lights are on, it's usually due to the front park/turn signal not being grounded.
If your Instrument Lights and Instrument Light Switch are properly wired they connect to the Headlight Switch Terminal that is Hot whenever Either the Parking OR Headlights are on ONLY, that is where the Tail Lights are also connected.
So NO instrument lighting without either Parking or Head Lights.
That makes me wonder just HOW original and correct IS this Hawk?
Geohawk63 Gotcha. I'm a bit stumped without more symptoms.
If it was a bad ground up front, the turn signal indicator would illuminate steady when park lamps are on, independent of panel lights; it would probably flash with turn signal, but the parking light element up front would flash instead of the brighter one.
So, does the indicator dim with your panel lights? Does it flash with turn signals, and are turn signals working normally?Whirling dervish of misinformation.
Yes that is how it is all wired. So strange but it has fixed itself now!Originally posted by StudeRich View PostIf your Instrument Lights and Instrument Light Switch are properly wired they connect to the Headlight Switch Terminal that is Hot whenever Either the Parking OR Headlights are on ONLY, that is where the Tail Lights are also connected.
