I'm working on a 61 6cyl wagon at the moment. Just swaped in a 62 ohv 6 with overdrive that supposedly had 10k miles on it before it was removed for an Ls swap. Any way I have the car on jack stands with the rear wheels off. Engine runs very well trans shifts through all gears. Cleaned the governor points and got the solenoid to click in and out when the speedo hit around 30mph, but it never acts like the overdrive actually kicks in. As in the speedo never moves up after the solenoid clicks in like I think it would.
Is it just because there is no pressure on the drive line to lock the blocking ring in or is the something internally that may be damaged?
I removed the solenoid and checked its travel and its working fine. It is a little difficult shifting from 1st to 2nd sometimes.
I do still have the front end off the car replacing the fenders so i can't take it for a test drive just yet.
The overdrive cable is hooked up and pushed in all the way. Double checked the lever on the trans too.
Thanks
Thanks
