259 two barrel carburetor options ???
  • Fuel System: 259 two barrel carburetor options ???
    Good day , we have the 1960 Lark with 259 with two barrel intake . Has on it a Stromberg that somebody put on it off a 1965 mopar .This is a very small intake bolt pattern and I am not going to any kind of fuel injection on this old girl . But I love a good two barrel and I was needing some imput from those out there that would know what options I have on this without changing the original intake . Not a show car , just a really great driver and I drive it every day here in Tampa . The Stromberg , is that the only one to fit thgis bolt pattern??The bore size on it now is 1.630 . The bolt pattern now is 3.250 across c/c and 1.870 c/c on the bolt holes for the carb . I want to drive this car to California next spring and want reliability and decent fuel metering . Thanks again . Joe in Tampa .
    I contacted Holley and there tech people were not able to answer anything on this , which I found a little strange .
      The Holley tech guy's parents weren't even born when your car was new.
      But why look for trouble? Studebaker Strombergs are still thick on the ground and a cinch to rebuild. The only thing to watch for is the throttle shaft being worn in the carb base bore.
      jack vines
        Stromberg WW is hard to beat. Don't mess with a Holley
          So do you have an idea for finding a good Stromberg ww core that will work /// number is 6-0123 Stromberg ,is what the Lark was supposed to be originally . Thanks
            Does it still have a PCV Valve and Hose from an Adapter under the Carb. like Calif./New York 1960/'61 located and State Mandated & Modified Cars, or None with a Crankcase Ventilation Draft Tube to the Air like other States?
            The reason I ask is the 6-123 has no PCV Fitting, but very similar WW's are available for '62 to '64 Models with a PCV Fitting in the Base at the Rear which would make a cleaner, better setup than a "Modified" one.
            All of course Used, to be Rebuilt with current Repair Kits.
              I have at least 3 2bbl carbs you can have at no cost. I live just down the road near Parish.
              78 Avanti RQB 2792
              64 Avanti R1 R5408
              63 Avanti R1 R4551
              63 Avanti R1 R2281
              62 GT Hawk V15949
              56 GH 6032504
              56 GH 6032588
              55 Speedster 7160047
              55 Speedster 7165279
                There's a Stromberg 6-123 on ebay right now (not mine).
                https://www.ebay.com/itm/REBUILT-STR...8AAOSww-lfhKHd
                3H-C5 "The Blue Goose"
                  After reading alot of good posts I believe running a good two barrel ww will be great for my old Lark convertible . The carb that is on there now is a combination I think of many different Strombergs so I would love to come to Parrish and pick up a core that will keep this car running right for years to come ! love this forum and its members .Joe
                    Went through my stash of carbs. I have 4 Stromberg WW. 2 have provisions for PCV. 1 has the choke in different location - no PCV. All fit Stude 2bbl manifold.
                    FWIW, I also found 2 Carter RBS and 1 Carter AS. 1bbl of course. If anyone has a need ...
                    78 Avanti RQB 2792
                    64 Avanti R1 R5408
                    63 Avanti R1 R4551
                    63 Avanti R1 R2281
                    62 GT Hawk V15949
                    56 GH 6032504
                    56 GH 6032588
                      Man that is great news on the Stromberg WW carbs , how do I get to hook up with you 64studeavanti ???? Joe in Tampa 813-389-9198 cell anytime
                        I left you info in response to your Private Message.
                        78 Avanti RQB 2792
                        64 Avanti R1 R5408
                        63 Avanti R1 R4551
                        63 Avanti R1 R2281
                        62 GT Hawk V15949
                        56 GH 6032504
                        56 GH 6032588
                          thanks 64studeavanti , will check it out !
                            The carb used on the early 318 dodge motors fits the 259 small pattern. I bought a new carb off Amazon for 89 bucks. It needed a phenolic spacer to raise it up 1/2 inch for the linkage to clear. It runs like a champ. I rebuilt the original stromberg but still ran crappy.
                              I have a bone stock original '59 Lark V8 automatic with the original (25,000 mile 2 BBL).
                              A few weeks ago I had occasion to start it after 2-3 years of dormancy, in order to move it. 2 Pumps and a fresh battery charge and it started right up.
                              Why would anybody change out that sort of reliability? It is 60+ years old!
                              Good luck with yours.
                              Bill
