My brother installed two of the 63 & later front anti-roll bars on his 57 Packard Clipper. One is stacked on top (or under as installed) of the other. A second pair of brackets were modified to accomplish this. It works quite well and is certainly CASO-compliant.
--Dwight
Rear sway bar for 1957 Packard station wagon
I could never find one of the OEM rear bars when I needed one, so bought 2 or 3 of Dave T-bow's. His are 3/4" diameter, instead of the OEM's 5/8". They are identical, and I doubt they interchange with any other car on the planet. For a front bar, I never bothered with other than the 63-66 V8 bar. it is 3/4", with sturdier mounts than the earlier bars. Worst example of an OEM front bar is the 56J, which used the same 5/8" bar as later 6-cylinder Studes. On the 56J, it is a joke, so I always installed the 63 and later V8 bar, which proves handling significantly. I am sure a larger bar, maybe 7/8" or 15/16" may be even better, but the 63 and later is readily available, reasonably priced, and a bolt on.Last edited by JoeHall; 11-26-2020, 06:34 PM.
Originally posted by Dwight FitzSimons View PostDave Thibeault sells (or, at least used to sell) larger front and rear anti-roll bars. I assume Dave didn't have the bars made specially for Studebakers, so they are probably from some late-model American car, with custom-made brackets. If you want to source the bars yourself perhaps Dave will sell just the brackets.
--Dwight
--Dwight
i read1982-1992 z28 and trans am bars fit the front, who makes the brackets? all the way to 1 5/16
Thanks. I have never seen one I don't think....but I am not that knowledgeable on these grand cars.
Originally posted by 5brown1 View PostMy friend is installing a GM front sway bar on his 57 Packard wagon and was asking me about a rear sway bar. He searched but couldn't find any information.
So my question is - will rear sway bar from a 57 or other years Studebaker President fit it?
Your friend will be very happy with the improvement that a heavier front bar, and the addition of the rear bar, make to the car. I've installed the rear bars on all of my Studebakers (the ones that didn't have them from the factory that is). He should also consider installing a good set of gas shocks front and rear while doing all this other work.
I'll be interested in seeing what Studebakers ever had rear sways.....Avanti maybe?
So my question is - will rear sway bar from a 57 or other years Studebaker President fit it?Tags: None
