My friend Warren has a 1951 Champion he just got back from a mechanic that re/installed his engine put in an electric fuel pump and other work. Now the clutch chatters really bad and grinds or won't go into 1st gear. Evan chatters going into 2nd. Mechanic does restorations etc. but alluded that some old cars just do that. Horse pucky! I told Warren things were really out of adjustment, have him fix them or he would not have a trans. for long. Frankly, I'm sick of seeing Warren paying out for unacceptable work. What things can he tell mechanic that will fix this problem? Roadster Dave
Chattering clutch and grinding gears
Bad motor mounts can cause clutch chatter. And a clutch that fails to release fully will cause grinding when one attempts to engage a gear. Some models have had an issue with the throwout bearing forks rotating on the cross-shaft. Generally not on six-cylinder cars, though.Gord Richmond, within Weasel range of the Alberta Badlands
- Likes 1
It is possible the the Clutch Housing Dialed-in Fit to the Engine was disturbed. Now the Trans. is misaligned to the Crank centerline.
The Alignment Dowel Bolts were improperly installed or Not at all.StudeRich
Originally posted by StudeRich View PostIt is possible the the Clutch Housing Dialed-in Fit to the Engine was disturbed. Now the Trans. is misaligned to the Crank centerline.
It is not adjusted properly. The clutch is not fully disengaging so that, even with the pedal depressed, the gears are still turning in the transmission, hence grinding. Sometimes the clutch will chatter if you re-install the old one backwards. The 'mechanic' sounds like a complete doofus so that is my bet. I'm not that fond of pulling transmissions so if I had to remove one I'd put in a new disc and probably a throw-out bearing. The flywheel and the pressure plate can get grooved and glazed on 70 yrs and that will certainly make it chatter. You really can't mess up the dowel pins--but doofus could have easily have lost them!
Originally posted by altair View Post
Richard I agree with everything you say but how can you "improperly install" the pins? Maybe not at all or only one pin.StudeRich
