My goal is to replace the stock column on my '54 coupe with a Saginaw-based tilt column that looks close to stock. The goal is to respline my stock wheel to the GM pattern and use the stock turn signal arm and the column painted to match the stock color. It would be for a floor shift car with the stock key on the dash. I'm aware that most factory columns have the key on the column as well as the shifter, but understand that those can be shaved off if I can't find a smooth column with no key/shifter.
Has anyone found a Saginaw tilt column (GM/Jeep/Mopar) with the right length or easily reduced in length to fit the C/K cars?
I know that there are aftermarket columns, from the poor quality Ebay columns made from solid Chinesium and the high quality Ididit or Flaming River columns that are beyond my budget., but I'm looking for a used OEM unit that would be reasonably priced and of production quality.
