I have just acquired a lark. In checking the master cylinder [to top it of. But what type of brake fluid is in there. Is there any way to find out if it is type 3 fluid or synthetic fluid. Any ideas on this matter
Brake fluid type
You can tell by the slipperiness and Odor of real DOT 3 Brake Fluid, probably caused by the glycerin and alcohol, otherwise known as glycol Gliseron in it.
Most Cars you find have DOT 3 or 4, possibly due to the huge COST difference between 3 & 4 vs 5.
The DOT 5 Silicone Fluid has a very different Odor and almost none, very Mild.
Also, most DOT 5 made in the last 20 years is Purple not Yellow/Tan.StudeRich
Originally posted by Bob Beckert View PostI have just acquired a lark. In checking the master cylinder [to top it of. But what type of brake fluid is in there. Is there any way to find out if it is type 3 fluid or synthetic fluid. Any ideas on this matter
Synthetic fluid is compatible will DOT 3. Use it. It is far less hydroscopic than Walmart fluid so less water, less rust. I use Valvolene synthetic fluid. Flush it really well. Avoid silicne as it softens rubber and is tough on brake light pressure switches. Be sure no cylinders leak. If they do replace them as they are likely beyond honeingLast edited by Jeffry Cassel; 10-14-2019, 05:41 AM.
Originally posted by Jeffry Cassel View PostSynthetic fluid is compatible will DOT 3. Use it. It is far less hydroscopic than Walmart fluid so less water, less rust. I use Valvolene synthetic fluid. Flush it really well. Avoid synthetic as it softens rubber and is tough on brake light pressure switches. Be sure no cylinders leak. If they do replace them as they are likely beyond honeing
I'm not trying to start an argument but all the esters are hydroscopic no matter where they are purchased. Silicone is not. Just trying to avoid any issues with implementing the use these fluids.
Bob
- Likes 1
And what is Walmart fluid? Is it not a DOT 3 or DOT 4? Then it has to meet specifications of that type.
The major problem with brake fluid is the terminology has changed. 30 years ago, when someone mentioned synthetic fluid, they were talking about silicone DOT 5 brake fluid. Now a-days, synthetic is used as a term for non-silicone brake fluid by some manufacturers and brake fluid users, and does refer to silicone DOT 5 by other brake fluid users. So, unless the DOT numbers are being discussed, don't believe you understand what people are talking about!Frank DuVal
50 Commander 4 door
- Likes 1
Originally posted by E. Davis View Post
Easiest way is to dip your finger into the fluid and touch a little to your tongue . Type 3 will have a definite acrid taste. Type 5 is usually purple in color, type 3 is clear or slightly amber.
- Likes 1
Believe me it works. When I was young and worked in a garage/gas station we had to learn little tricks like that because we didn't have time for lab checks on every question. I worked with a guy that could tell you the strength of anti freeze within 5 degrees by tasting it. Couldn't get away with it now days I guess.
- Likes 1
