I may be mistaken but I seem to remember that the main reason for using 10W motor oil was so Studebaker could advertise "no special oil needed". If you'll recall, that trans was VERRRY advanced for its day. When Studebaker began working with Detroit Gear to build it, they laid down certain specs. I think the use of motor oil instead of trans fluid was one. Plus direct drive clutch, "park" and "reverse" lockout.
I can remember driving down the road at a good clip and to show off, flip the lever down into "R" to show that it wouldn't hurt the trans. Try that with ANY OTHER trans!
Granted, modern trans fluid is better in modern transes but I have used 10W for many Studebaker Automatics with NO apparent ill effects.
Once in the 50s I was on a trip, stopped at a station, checked the fluid which turned out to be about a pint or so low. I told the station guy, "Just get me a quart of 10W." Believe it or not, he refused to do it. "You can't put MOTOR oil into an automatic. I'm not gonna sell it to you." Had to go to the next station and didn't tell 'em the reason for needing the 10W.
However, I also seem to remember that about '52 or so, Studebaker began recommending Type A fluid for that trans.
John
John
