I have a new 12 volt battery and 12 volt coil and a resistor. I was told that I wire one end of resistor to the coil and one to the distributor. I’m green on the electric part and could use some help
6-12 volt conversion
For a six to 12 volt conversion, start with the $10 PPD book, "The Official 12-Volt Conversion Guide" advertised in every issue of "Turning Wheels".Gary L.
That is precisely how not to do it. First off, not all 12 volt coils require a resistor. Some have an internal resistor, and some are wound such that they simply don't need one. If you do use a coil that requires an external resistor, it goes between the (+) terminal of the coil and the ignition switch. Assuming, of course, that you wire the car as 12 volts, negative ground.If the car has overdrive, can I respectfully suggest you leave it as six volts. You cannot put dropping resistors on the solenoid, and expect it to work.You will also need regulated voltage reducers, such as the Runtz, on the fuel and temperature gauges, unless the temp gauge is the direct-reading kind with a capillary tube going to the engine head.Gord Richmond, within Weasel range of the Alberta Badlands
Actually, you need a 12 volt, TWO-terminal solenoid from an early 12 volt car. Later overdrives used a 3-terminal solenoid that dispensed with the relay.Gord Richmond, within Weasel range of the Alberta Badlands
Generally, you do not have to replace switches when going from 6V to 12V. You will most likely have to rewire the floor starter switch internally or replace it. How/if you can use the floor starter switch depends more on what your starter solenoid looks like. Some take a ground on the little stud to energize and some take 12 volts on one of the little studs to energize. I don't remember which is which, but the change in how to energize the solenoid came at the same time as the switch to 12 volts.
As a rough rule of thumb, the things that MUST be changed in converting from 6V to 12V are:
-light bulbs - all of them
-fuses
-motors
-solenoids - all of them
-relays - all of them
-battery
-Generator/alternator
-voltage regulator
-radio
-ignition coil
-regulator added to 6 Volt gauge
Things that do NOT need to be changed are:
-switches, including overdrive governor
-wires/wiring (If the old wires are good)
-distributor points
-spark plugs
-spark plug wires - if they are good
Things that are being debated, or upon which there is not common agreement:
-starter motor
-distributor condenser
-horns
-clock
As another general rule of thumb, most voltage reducing devices get hot and do not deliver the quality and exactness/regulation that the device (fan, radio ) needs to operate properly. In most cases, not all, the voltage reducing devices will not work satisfactorily. It is best not to put your hopes in them.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
