Rear axle splines
  • Rear Axle: Rear axle splines
    I have a 67 Avanti. What number of axle splines does it have?
    thanks in advance
    Studebaker used 19 splines. The later Avantis used a finer spline, but not sure when they changed. You might pull one to be sure. It's good to do to repack the outer wheel bearings anyway.
    Bez Auto Alchemy
      I believe flanged axles were 31 splines. My '63 has tapered axles and 19 splines. I think '67's were flanged. If you have a big nut holding the axle in you have tapered. No nut---flanged.
        You might as well put zerks in to make packing the outer bearings much easier too. Think I wrote up the procedure a deckade or more ago and posted it here.
        65 2dr sedan
        64 2dr sedan (Pinkie)
        61 V8 Tcab
        63 Tcab 20R powered
        55 Commander Wagon
        54 Champion Wagon
        46 Gibson Model A
        50 JD MC
        45 Agricat
        67 Triumph T100
        66 Bultaco Matadore
          My 66 had tapered axles with 19 splines like Studebaker. Avanti used a HD Dana 44 with 30 spline axles around 1970 and up. 67 to 69 might have used the 65/66 Studebaker flanged axle rear end with 27 spline axles. The key is whether it has flanged or tapered axles. An early 67 might still be tapered.
          james r pepper
            How many splines does the pinion gear have on a 63 Avanti?
