Originally posted by wittsend
View Post
The main bearing cap mating surfaces are nipped .001" -.003" as required on a Sunnen cap grinder.
The main caps are then installed on the block and torqued to spec. As you suggested, removing material from the mating surface of the caps results in an oval bore, wider at the sides. The line hone mandrel is long enough to go through all five main bores and driven by a large drill motor. About five strokes, remove, measure all five bores with the Sunnen dial bore gauge. When finished all five bores will be round and original ID to within .0005".
When the crankshaft is turned .010" - .040" undersize, the bearings then used are appropriately thicker to maintain the required clearance.
You did ask this question, and while not germaine to Studebaker discussions, 21st century design blocks and connecting rods are manufactured in one piece and the main caps and rod caps are separated by cracking them off. This results in a slightly jagged mating surface which fits together perfectly. Obviously these can't be nipped flat to resize them, so the bores are honed to a specified oversize and thicker shell bearings are available make up the material removed.
