Electric Fuel Pump Max Acceptable Pressure
  • Fuel System: Electric Fuel Pump Max Acceptable Pressure
    What is the max acceptable pressure at the carb inlet?
    I have read that the 8psi output of a typical pump is too much and will flood the carb. I see that "low pressure" electric pumps are now available that only produce 4psi. Is this low enough to work with our carbs and not cause a problem? I have a WCFB on my Hawk and a Stromburg on my 54 Commander. I currently have a Holley regulator on my Hawk and the pressure at the carb is only about 2.5 - 3.0psi.
    Wayne
    "Trying to shed my CASO ways"
    2.5-3 pounds. I have an Edelbrock 1403, and I had to install a regulator on my Carter electric pump. New carb, float properly adjusted, but the pump over powered it...
      I have a "Cube" type fuel pump on my Studebaker (350 Chevy/Edelbrock carb.) that is rate at 4 pounds. It also feeds to the stock mechanical fuel pump. While primarily for priming it seems to deliver all the fuel necessary without a regulator (though I think the mechanical pump may be taking care of regulating pressure). On my Valiant (also Edelbrock carb.) I have a 4-7 PSI "Cube" style pump. Because of prior issues with the stock mechanical pump I do have a regulator and if I recall correctly set to about 4 PSI. In this case I have bypassed the mechanical pump. In both cases "Cube" pump works well. So, 4-ish PSI seems close.
      One thing I have noticed about the Ebay (Chinese) "Cube" pumps is if they are rated at 4 PSI or lower the GPH is higher (90) and if rated at 4-7 PSI the GPH is lower (70).. so, they may both be the same save for a restrictor that increases the pressure at the sacrifice of volume.
      If used only for priming the PSI probably doesn't matter - much. Given these "Cube" pumps cost about $15 shipped it is actually cheaper to buy both pressure types (low/high) than to have to $pend $30+ for a regulator (Holley) if the pressure is too high.
        The lowest pressure that meets the needs of your engine and the way you drive is what you should shoot for. For most street cars 4 psi is plenty, but often less is required. I had a car with 3 carbs with a regulator set at 1 psi and it worked fine at full throttle, over 3 miles at least.
          I agree with bensherb. I regulate my Holley rotary pump with a resistor to lower the voltage, so I get 1 to 1 1/2 PSI on my 50 Champion, and it works fine at all speeds.
