I recently picked up a TR-3550 (non-TKO), Ford configuration, with the intent on adapting it into my '54 Commander Coupe with the original 232/3spd-OD(T86E\R11). I've taken some trans bolt pattern measurements for both the T86 and the 3550 to come up with an adapter plate to machine (CAD screen-shots attached). There are a few details to work out for a custom machined pilot bushing and the spline location and its exposed length in relation to clutch motion but I also have some rudimentary questions regarding Studebaker bellhousings, flywheels, clutches, and release mechanisms. I'm having trouble finding these details with various searches though I have a feeling a lot of it is "common knowledge".
I believe it will be fairly straight forward to get this transmission into the original 232 bell with its clutch assembly and possibly even throw-out bearing/release linkage. I'm overlooking shifter placement and driveshaft length for now as I think these will be fairly straight forward tasks to solve once the transmission is in place. The adapter plate lays out pretty well and with a thickness of 0.55" seems to place the splines on the 3500 in the same region as the T86 would originally be. The images attached show the T-86 mounting face at the location that the bell housing face would be and the proposed adapter plate mates to that same face while the 3500 face is mated to the other side of the adapter plate. The T86 trans is the one shown transparent and has the longer pilot bushing diameter region. The adapter plate is also shown as transparent just to see more of how things are positioned. One main difference between the T86 and 3550 (besides the obvious) is the length of exposed spline. The T86 is about 2" of exposed spline while the 3550 is about 1.54", a difference of 0.46". Is this because the overall TO bearing travel of a lever style pressure plate is greater than a diaphragm spring style? I believe the GM 3550 bearing retainer is shorter (and possibly smaller OD on the TO bearing riding surface) so maybe I need to change to this bearing retainer to maintain the spline exposed length?
Here is a quick run-down of the dimensional differences between the T86 and TR-3550 (Ford config):
Item: T-86 / TR-3550
Bearing Retainer Bell Housing Pilot Diameter: 4.123" / 4.844"
Bearing Retainer TO Bearing Riding Surface Diameter: 1.497" / 1.431"
Splines: 1.125"x10 / 1.055"x10
Pilot Bushing Riding Diameter: 0.743" / 0.668"
Some base Studebaker questions I have are:
-Are all 232/259/289 Studebaker engine bell-housing bolt patterns the same? I think the answer is yes.
-Is a 259/289 10" to 10.5" clutch bell housing required to run a larger clutch on a 232 or is the 232 bell housing large enough?
-Is a 259/289 10" to 10.5" flywheel required to run these size clutches on a 232 or will it bolt to the original 232 flywheel? I imagine it won't bolt to it and the larger(or just different) flywheel is required.
-If the different flywheel is required, I believe the tooth count of the ring gear and possibly diameter are different meaning my original starter won't be compatible and will damage the starter and/or ring gear? I think I found this much on other posts.
-If needing a different bell housing, will it bolt right up to the 232 and the original bell housing located engine mount?
-It looks like the later 259/289 trans bolt patterns are different (wider and asymmetric) than the 232. Is that correct and do most not bother adapting modern transmissions to the older 232 style bells?
I'd like to migrate to a larger clutch and run the Jeep (75 CJ5 V8 application, AMS 01505) clutch for ease of sourcing and for cost. I would also like to entertain the use of a hydraulic throw-out bearing/slave cylinder setup. However, I think this would require moving to a diaphragm clutch since that's what most of the hydraulic slaves are meant to be used with.
Again, I think adapting to the original bell with a custom machined plate will work out (provided I answer the spline exposed length question) fairly well but would also like to plan ahead for a larger clutch and need to know the other items needed for that change.
Thanks,
Wayne
Thanks,
Wayne
