Saw this recently.
Am impressed with (a) The annular flow booster venturi ring....
And (b) The bolt on GM trans adapter linkage piece.....
And (c) It comes in 'satin' and 'Endurashine. (Satin is like the old WCFB and AFB)
That GM trans adapter piece has been a bugaboo with Stude's using the cast iron intake
as the trans kickdown cable link hits the intake heat crossover.
This new carb looks like it addresses that situation quite nicely.
Probably going to try one out soon...
http://www.edelbrock.com/automotive/...ors/avs2.shtml
(copy)
(copy)
Edelbrock AVS2 Series™ Carburetors |
The AVS2 Series is the next generation in Edelbrock carburetors. The AVS2 features annular flow primary boosters with a new calibration for improved off idle and cruising performance. The annular flow booster design delivers improved fuel atomization to eliminate flat spots that may be encountered when the carburetor transitions from idle to full throttle. Each annular booster features eight, equally spaced orifices to improve fuel metering from idle to the main. The improved flow metering makes this carburetor ideal for use with a wide variety of small-block and big-block engines with either dual- or single-plane intake manifolds. The AVS2 includes both timed and full vacuum ports for ignition advance. | |||||||||||||
500 CFM, MANUAL OR ELECTRIC CHOKE (THE ULTIMATE PERFORMANCE CARBURETOR) Designed and calibrated for small cubic-inch engines and dual-quad applications such as our RPM Dual-Quad Air-Gap, Edelbrock C-26, F-28 and Street Tunnel Ram. For single carb applications, match with an Edelbrock Performer or Performer EPS manifold or other brands of similar design. Includes both timed and full vacuum ports for ignition advance. #1901/#1902 are calibrated for single-quad applications and factory equipped with: Metering Jets - Primary .095, Secondary .095, Primary Rod .070 x .052, orange spring (5' Hg). #1903 is calibrated for dual-quad applications and factory equipped with: Metering Jets - Primary .095, Secondary .077; Metering Rods - .070 x .052; #1904 includes Primary .095, Secondary .077; Metering Rods - .070 x .052; Step-Up Spring - orange (5' Hg). Use carb Studs #8008 or #8024 if needed. Match with an Edelbrock intake manifold for the ultimate induction upgrade. |
WHY IS AN ANNULAR BOOSTER BETTER? | |||
The typical downleg boosters (on the left), are located in the carburetor primaries and simply provide fuel down the center of the venturi. Annular boosters (on the right), feature eight equally spaced smaller holes for better fuel atomization. The improved fuel atomization eliminates flat spots when the carburetor transitions from idle to part throttle for better low rpm performance. The annular boosters can also potentially offer improved mileage in some applications. | |||
WHAT OUR CUSTOMERS THINK! | |||
