I was going to offer the tray out of the parts car I've got, but its already sagging too. Not horrible, but somewhat. It still has the support brace and brackets attached.
1963 Avanti rear package shelf is sagging from water and age
Originally posted by Gunslinger View PostHardboard has lasted in Avantis for over fifty years...no reason it can't do so for the next several owners. Plastic will work and work fine, but wood is easier to cut, drill and shape, cheaper to buy so why not keep using it?
for 5/16 hardboard? This is of the oldest Avantis out there also, a 1963 round headlight. I need headlight bezels too.
Originally posted by JLB View PostTom, not sure I understand "RAD Ideas"
window adapter brackets. I have made an extremely stronger shifter stick for 2004-2006 GTO B&M Tremec T-56 (they break
between the ball and the pin) and I just did a batch of sliders for seat tracks on a 1994-1996 Impala SS.
Originally posted by sals54 View PostI was going to offer the tray out of the parts car I've got, but its already sagging too. Not horrible, but somewhat. It still has the support brace and brackets attached.
I had considered using heat to bend the board back, I tried to wet it, but found it won't take on water, I think they put a ton
of glue on it and is soaked in. This could have easily been avoided had Studebaker ran the support brace from bracket across
to the other bracket. I may just let the guy recover it as is, and raise the rear up for a nice gradual rake to the rear glass.
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
I am replacing the rear shelf on my Avanti this week. I went to the local Home Depot and got sheet of 1/4 MDF board took the vinyl off the old one, and clamped the original over the MDF and just used a jig saw to trace/cut around the original. I drilled out the rivets from the brackets, drilled the holes and took off the brace, drilled the holes for the nutserts.
It fits great in the car. I will be putting on new vinyl and re-assembling it this week.1 Family owned 63 Studebaker Avanti 63r-1705 White with Orange interior , R2 4 speed.
Just purchased 63r-3623 R2 was a auto now dressed to a R3 with a4speed.
Originally posted by JLB View PostTom..........to be clear, you are not going to make the power window adapters, is that correct?
Thanks
John
I will be offering the bracket at some point, so far I have a rather large chunk of money into the RAD Ideas caliper brackets - would be nice to break even on that prior to putting out more capital. If you click the link in my signature things might make more sense about RAD Ideas, etc.
Originally posted by Endl98 View PostI am replacing the rear shelf on my Avanti this week. I went to the local Home Depot and got sheet of 1/4 MDF board took the vinyl off the old one, and clamped the original over the MDF and just used a jig saw to trace/cut around the original. I drilled out the rivets from the brackets, drilled the holes and took off the brace, drilled the holes for the nutserts.
Thanks all that responded.
Last edited by sbca96; 11-06-2018, 02:16 AM.'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
