Russ here, first post. I still own my second car, a 1954 Champion K I purchased in 1969 for $100. I have repaired the BW T96 transmission in the '54 several times in the 70's and the T96 in my AMC 6 cylinder years ago. I feel the T96 is a good quality lite duty transmission.
Several years ago, I wished to purchase a pre-war car with overdrive for highway cruising, so bought a 1939 Studebaker Champion G Coupe. The '39 is a far cry from my '54. Primitive fixed anchor brakes and plain rubber upper inner A arm bushings on the strangest design front suspension. Replaced all the brake components and the A arm bushings but the OD transmission is my problem now.
The 1939-40 Champions used a Warner T84 transmission. Sort of a pre-curser to lhe 1947 up T96, the T84 has a straight cut first-reverse gear and bushings instead of needle bearings in the cluster. The OD is not an R10, but uses an internal centrifugal clutch for engagement and an electric solenoid for disengagement back to direct gear. And this particular transmission was only used for 1939 and 1940. In 1941, the transmission was "updated" with 95% different internals. Even the transmission case and gaskets were different. Makes one think the 1939-40 transmission was inferior.
My problem is I can shift into 2 gears at the same time. This completely ruins my drive. No, it's not the remote steering column linkage; I've worked on that. The 2 rods at the transmission can be disconnected from the levers, I can place the rear lever in first gear then move the forward lever in second or high at the same time.
I believe I am caught in a recall campaign that should have been fixed in 1940, but the Studebaker dealer in town has moved away. In an old auto repair manual I found online, there was a repair for "goes into two gear at a time." The transmission has to be removed, the top cover removed, the second-third shift lever pin punched out, the inner lever moved toward the main shaft and the old interlock removed and a new "super duper" interlock installed.
Most of the old timers that worked on old pre-war Champions are gone. Does anyone have any information on first year Champion remedies for shifting into 2 gears at once?
Thank you for your help. I have enclosed a picture for your enjoyment.
