Ok. Need to pick your brains.
So, here's the deal: I have rebuilt and properly tuned the carburetor, replaced my plugs, fuel pump (mechanical), coil, and condenser within the last couple months. When I start the car cold, it fires up immediately and warms up smoothly, then runs at a smooth idle.
Except after I park for a bit (ten or twenty minutes) and restart the engine. It will fire up fairly easily, but idle high...really high, like I'm holding the throttle halfway to the floor. After a couple miles, it runs normally again.
I'm sure this is a heat soak issue at the pump. When I look at my fuel filter, after I shut the engine off, I can see it bubbling. I've fabricated an aluminum heat shield for the fuel pump, and isolated the carburetor with a 1/4" phenolic spacer already. I've been thinking of running the fuel through a radiator before and/or after the pump to try to help, but wonder if I should bother.
Anyone else have thoughts? Bearing in mind, we have alcoholic fuel here in AZ, and outside temps get pretty warm. The engine runs between the 1/4 & halfway mark on the gauge, and I've also disconnected the heat riser spring so it stays open. Also, I'm not interested in putting in an electric pump. There was one on the car when I bought it, and it was nothing but problematic.
Thanks in advance for your responses.
