I want to remove the parking brake cable from the rear hubs on a '50 Champion. After removing the hardware from the front part of the cable system, I'm not sure how to remove the cable from the hub assembly. I've removed the cable from the operating lever. The next step, per the shop manual, is to "Pull the cable rearward, remove the stop and then pull the cable forward and out of the backing plate tube. The "stop" is attached to the cable by some sort or machine operation. Any guidance on would be appreciated.
Sorry for the orientation, this is the first time I've not used Photobucket.
