Originally posted by reichsrundfunk
View Post
Thoughts on Oil Additives
Originally posted by 56GH View PostI've been trusting Hemmings Motor News and their motor oil for classic cars. No problems yet in my 1962 GT Hawk or in a previously-owned 1964 Cruiser.
Bill L.
Originally posted by jackb View Postmy question has always been: what objective, measureable evidence does anyone have of improved engine performance or other. Who can remember the NYC taxi study done years ago on different oils and additives in taxis that drove 24/7 for several years to measure (weigh engine components before and after 2+ years of severe service) engine wear ??? You can probably google the study... but the results were that additives did not affect (+ or -) engine wear.... Further.... as long as the oil was 10W-30 with the ASE burst on the bottle... all these oils performed the same. I can't remember Rislone for sure, but STP and others were a part of the study.
Originally posted by GrumpyOne View PostA 259 engine with 59K on the clock that has received adequate maintenance has barely been broken in and should need zero in the way of oil additives except for STP, (or a suitable substitute).
Choice of the proper viscosity (to me) would be in order. At your location I would choose 10-40 with some STP simply to provide the needed ZDDP(?) cam/lifter/rocker arm protection...
Originally posted by Bud View PostMy thoughts on this is not to add anything to the engine oil as I'm not as smart as the engineers at the oil companies. They design an additive package to use with their specific oil and adding anything to the oil can upset the balance of additives already in the oil. The best that can happen is nothing but lighten your wallet a bit and the worst could be long term engine damage. Any additive is a band aid to cover up a problem that should be addressed to make a permanent fix. If you feel that you need more ZDDP than what is in the oil you want to use, then I recommend finding an oil that has the additives you want such as Valvoline VR1, Brad Penn and most of the heavy duty oils such as Chevron Delo 400, Shell Rotella T, Mobil Delvac etc. Bud
Originally posted by tsenecal View PostI run Amzoil synthetic called Z-Rod. It has the ZDDP in it , and is engineered for older engines. It also advertises good long term storage capabilities. I think it is worth a look on their website to read more about it.
Originally posted by colt45sa View PostThe ONLY reason I would use Amzoil Z-Rod would be if I wanted to eliminate any further wear and extend my engine life indefinitely~!
Then there's also the little pellets you drop into each cylinder to "completely" rebuild the engine! I haven't seen them in many, many years but always wondered if anyone was ever taken in by that.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Was a Lubricant sales rep for many years. Our lab stayed on top everything that came along and while I won't say what there stand is, I used to tell folk that if there was and or is anything of value in various additives da oil companies would blend it in their brew. Just an opinion from old peddler,
Kim
Kamzack knows his S@#t!!! 50,000 miles with filter changes and 2 qts added on tow vehicle with oil sampling at 10,000 mile intervals made me a believer. i think Joe Hall might have had his tongue in his cheek, but to each his own. Really enjoying this Forum, keep up the good work everybody,till my ragtop project arrives i am on honey do duty!!! Doofus
Originally posted by JoeHall View PostFor every Stude oil change, I pour in 16 oz. of ZDDP, a quart each of Rislone, Marvel Mystery, STP, and Lucas Oil Stabilizer. I then top it up with regular oil.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
I have an 05' Hyundai Accent with 341,00 miles on the original 1.6 4 banger. Runs great and burns no oil. Know what additive I've used? None. Just the factory recommended oil viscosity.: 10w40. I've used Walmart's Super Tech at every 3,500 mile oil & filter change. My 84' Harley FLT has 241,000 miles. I use Harley's recommended 20W50 oil and change it and filter every 3,500 miles. It runs great and uses no oil. Additives? We don't need no stinkin' additives. Routine oil changes with filter is all you need. Save your money!
Originally posted by Kato View PostDo you find any oil leaks that were present get worse with this oil. I use Amsoil in my daily drivers and would definitely consider it for my GT but am always concerned with synthetic causing more leaks!
