My driver is a 53 studebaker on a 57 hawk frame. I also have a 59 hawk and and various parts.
You are right about the glitch. Later in the ad it shows a leaf and coil spring, but it calls it a long travel coil spring.
All the springs I have, about 6, are constant rate springs. And the pictures and manuals show constant rate springs, but that is pictures.
The Studebaker International catalogue picture shows a constant rate spring and list same springs for 1953-1966 except Avanti.
The spring from the Avanti in the 01/09/17 post standing next to the one he is using as a replacement is a constant rate spring. His proposed replacement spring is a variable rate spring. That alone seems to indicate that not "all" Studebakers had variable rate front springs UNLESS his spring is not OEM
My research over the last few days points to a constant rate spring being the best choice for front coil springs. However, short of having CSS or Eaton make a spring or buying them from SI, a variable rate spring might be a cheaper compromise.
I would love to know where you found your information that all Studebakers after 57 used variable rate for the front coils.
