Hi; after getting cast off, back into the shop to finish differential!! ('57 Golden Hawk, non-TT)
Got the assembly OUT (originally just to clean), and found HORRIBLE spalling and pitting on the bearing races (inner axles). Fortunately the Pinion was ok; original owner must have run it really low on gear lube, and pinion sits lower so it survived, thank goodness (would hate to take those races out and re-set tolerance!)
Speaking of tolerances, have two questions:
1) after COMPLETELY PRESSING on new Timken bearings, (same part number as originals after 60 years!) reassembled into housing, and torqued down the caps. Original shims all EXACTLY same positions, even filed any 'ragged edges' to keep original thickness.. VERY careful about this, AND completely pressing bearings to their stops.
When I rechecked for ring gear run-out, I got ZERO. It turns with some resistance but smoothly (and easier using pinion yolk), so NOT binding...
Before Disassembly, I had 0.003" run-out on the ring gear; max per shop manual (when "just checking" it); NO MINIMUM is stated.
And (see snapshots from manual), when completely rebuilding one, they talk about a "pre-load"; so does this mean I'm OK (maybe 'perfect' :-) as-is?
Again, it states MAXIMUM of 0.003", but NO MINIMUM is stated anywhere for run-out.
2) for backlash, spec is .003-.006". Best I can measure is 0.010. (Also please look at the prussion blue imprints for meshing, which looks good to me but I'm no expert...)
I ONLY pulled the pinion OUT, greased both bearings and cleaned it all up, put the FRONT shims (and new seal) back on, and put it back together, so the INNER race and shims didn't even move. Should be factory minus wear.. Thus, I'm guessing that extra backlash is from wear, and wondering if an .010" vs 0.006" max spec is enough to justify the massive job of trying to pull out pinion races and reset, multiple times... without Stude tools either. Massive also, for me, as I can't lift and carry the differential assembly even; had to roll it over to my bearing press, etc.. on a wheeled chair..... Whadda you think? Not going to be racing, but don't want it grinding on me either...
Thanks!
Barry
Thanks!
Barry
