I'm getting ready to order a driveshaft for my Indy car project. I'd like to get some comments on universal joint angles from people who have needed to get custom driveshafts made. I have read that the ideal situation is that the axis of the front yoke is parallel to the axis of the yoke on the rear axle, even if they are not in the same plane, i.e. at the same height. Also, the u-joint angles should be 3 degrees or less. I can't get there.
The 1937 President straight 8 engine sits exactly horizontal, will generate 150-200 hp. There is a 1936 President 3-speed transmission without overdrive or freewheeling. The 1928 Commander GB-W rear axle (3.31 ratio) is currently tilted upwards at a 3 degree angle. The pinion yoke at the front takes the same u-joint as all Studebaker cars from about 1935 to 1966, a Spicer 1310 or SKF UJ369. The driveshaft I have from the 1928 car is an oddball thing with a 5" diameter mounting flange. The u-joint is encased in a sheet metal shell, but it has a cross-like forged donut with the 4 arms sticking out. It's probably something like a Spicer 1330 with 1.063 dia. caps and about 3-5/8" from end to end. The drive shaft was 2" diameter and has a slip-joint in the middle. My new driveshaft will be under 22" long.
I'll need a shaft about the same diameter with 2 different type ends. The front angle may be as high as 7.8 degrees and the rear angle should be about 4.8 degrees. This is more than I wanted to wind up with, but there don't seem to be many options. I really, really do not want to move the engine now! I can adjust the tilt of the rear axle a bit, as I currently have a set of 6 degree shims under it to get it to the 3 degree up position. At 60 mph, the engine and driveshaft should be turning about 2200 rpm. According to a table I found showing maximum u-joint angles versus rpm for about 3000 hour life, I think I'm mostly OK. Apparently, doubling the joint angle cuts the life expectancy in half. In my wildest dreams, I would like to run the car in some vintage racer events and get it above 100 mph, but we're talking about a few minutes above 3000-4000 rpm in 3rd gear. In the end, u-joints are pretty cheap to replace every few years.
I'd like to avoid doing anything grossly dangerous or generating horrible driveline vibrations. Do I need a double Cardan joint at the front to halve the front angles? Do I need to rotate the axle downward 3 degrees so that the flange points horizontally like the engine, even if it makes the height difference and joint angles worse? Anything else I should do to get the best result? Or, is this going to be OK as is?
Oh, and I can't get the #$%! rusted caps out of the u-joint. There are no wires or clips to hold them, only that domed cover held them in place for the last 88 years. The cross can't move sideways, so I can't push on the caps. What's the secret to getting them out?
