I bought my Craftsman LT1000 lawn tractor with 6-speed manual transmission from Sears back in 2001, along with a 3-tub bagger system and a front-mounted snow blower. The 16 hp and 42-inch mower deck are enough for the lawn area I have. However, after 15 summers and 14 winters, the tractor is definitely showing its age. When it's working right, it does cut the grass OK and it throws the snow well. While the body is rust-free (stored in a shed) and the engine runs fine, the chassis and mounting points have developed stress cracks from flexing. It has 800-1000 hours of actual operating time. It may be time to replace it, but it won't be cheap. Here's some of what I have fixed over the years:
Welded multiple stress cracks in the stamped-steel front axle
Replaced the transaxle once (no reverse)
Welded and reinforced the transaxle mounting brackets because of fractures and cracks
Welded on 3/8-16 nuts where threads had stripped from pierced and threaded holes in chassis
Drilled and tapped replacement transaxle for larger mounting bolts due to stripped threads in aluminum housing
Fabricated new skids for the bottom of the snow blower
Of course, this doesn't include replacement of mower deck spindles on 4 or 5 occasions due to hitting rocks with the blade, but that can always happen here in New England. Ditto for replacing shear pins in the snow blower when it tried to eat the Sunday newspaper buried under the snow.
I'd go buy a new John Deere hydrostatic drive tractor, like a D125, but it would also mean getting a new bagger set-up and a new snow blower, etc., doubling the cost. Kind of like CASOs, frugal New Englanders try to avoid spending big bucks. On the other hand, doing full overhauls on the tractor is getting old and tiresome. Winter is coming and I don't want to get stuck without a way to clean my long driveway. Is spending $100 for replacement parts now and then just part of the game? How do I know when to quit fixing the old one and start all over again? How does anyone rate the smaller John Deere products relative to others? It seems like Husqvarna is the company that owns and makes many of the other brands like Craftsman, AYP, MTD, Bolens, Yardman, Huskee, and most of the ones from the "big box" stores, perhaps even the smaller John Deeres.
See this for who makes which brands: http://todaysmower.com/2011/riding-mower-brands/
