Alternative to mobility scooters- the trike
  • Alternative to mobility scooters- the trike
    Due to advancing rheumatoid arthritis, I have gotten to a point where I still get around OK, but locations that require extreme amounts of walking are getting too painful. I am only 58 years old. I simply could not bring myself to buy one of those mobility scooters. I ended up finding what to me is a pretty good compromise. I am sure that there are others in a similar situation, so I’m posting the information for you.
    In July I was at the biggest car show in our area each year. This year was the first time I didn’t cover the entire acreage, because my feet and knees just got too painful. There was a younger couple there driving something I had not seen before-basically a cross between a scooter and a three wheel bicycle. It’s a front wheel driven electric trike that can be operated either sitting or standing. The result is a comparatively light, easy to transport mobility vehicle with good range and capacity combined with a higher seating position. They gave a very strong recommendation of them.
    The basics are it holds up to 400 pounds, can go up to 30 miles on a charge, top speed of 22 mph in high gear. They come with an LED headlight and taillight, LED running lights underneath, reverse gear, electric horn, and a USB port to charge your phone. It also comes with a clip on front basket. It weighs about 75 pounds, and folds flat so that it can fit in most any car trunk. Actual cost was $1800. Other than accepting that I needed it, it has been a Godsend.
    After seeing them at that car show, I started doing research. The couple had told me to always disregard the price – the price is usually in the neighborhood of $4000, but they always have a buy one get one/show price/sale that means you can get one for half of that or less. As I started doing research, I found them as cheap as $500. But like anything else, you get what you pay for. The one I saw for $500 had a smooth front tire and hard plastic rear tires. All of the specifications were less: less weight capacity, less range, less speed; and worst of all, the hub drive motor was much less wattage. Mine is the highest wattage I have found in these at 1000 W. The cheaper ones were as low as 300. And I can tell you that even at 1000 W, there is a limit to how steep of a grade it can climb, for example. Basically, the more capacity and the more power, the more cost. I would not recommend getting the lesser ones.
    During my shopping I had focused on a company called Five Star Scooters. Theirs have lithium ion batteries, which gives a little better range at a little less weight than standard lead acid batteries. And, it was the brand that the couple at the car show had. They are easy to find online, and in fact they have videos on YouTube where you can see them a little better. However I ended up buying mine at our state fair for a few different reasons: one, I was able to see it in person and test drive it; two, the battery is flush mounted underneath instead of a big hump between your feet, which makes a big difference in comfort and three, I was able to use it that day, and two other days at the fair because it was already available. To say that it improved my coverage of the 365 acres of our fairgrounds is an understatement. I’ll post a link to that company below.
    I’ve only used it a few times so far. I used it for two days at the state fair, and around our city a little bit. Two weeks ago I took it to Hershey, and it was absolutely fantastic there. I went up and down pretty much every aisle over the course of two days, which they say would total 29 miles. I don’t really know how many miles I covered each day with retraces and so forth, but I rode it about five hours, then took it in the Giant Center and plugged it in and walked around for a couple hours. Then I’d go back and get it and finish out my day.
    A full charge I guess takes about five hours. One drawback is that the battery pack can only be charged while in place. I’m sure that could be changed, I haven’t looked into that yet. Probably I will just buy a second battery pack so that when the first one runs low I can just switch it in about 30 seconds and continue on. They say the lithium ion units have more range, but then they’re more expensive to buy. Maybe it will make sense at some point to convert this one to lithium ion.
    Mine had a retail price of $3999. Actual cost was $1800, plus tax where applicable. It comes with a two year warranty. Replacement parts available through the company. Tires are fairly common and easy to get if needed. One definite recommendation I have, get the optional knobby tire. It has enough torque that you will constantly be spinning the standard tire.
    Couple other things – you have to learn to keep your weight slightly forward for two reasons- one, it is fairly easy to spin the tire if you’re leaning back and two, if you lean hard against the back rest going up a hill, they can tip over backwards. In fact, I saw it happen. Really though, it’s not hard to get the hang of.
    In the end, it’s not perfect, it does leave some to be desired. But it will fold down far enough to go into the trunk of most cars so you don’t need to have some special rig to carry it. If 75 pounds is too heavy for you to lift, you could easily remove the battery pack which is about half of the weight, and load the two pieces separately.
    I expect that in a couple years they will advance quickly enough that this one will be pretty primitive. But for less than two grand it does pretty well, and when there’s a big advancement I’ll get a new one. Best of all, it’s better than the regular scooters where you ride around with your nose at the level of everybody’s butt. All in all, for most people, all things considered I would recommend them.
    Euroshine has been around for over 40 years. We sell and manufacture quality, solution based products that are affordable. From workout equipment to home goods, cookware to pillows, everything you need is right at your fingertips. Shop today!
    Proud NON-CASO
    Romans 15:13
    Deuteronomy 31:6
    Proverbs 28:1
    Illegitimi non carborundum
    That is a handsome trike Bob!
      If they are ADA compliant, they are 'tax exempt', provided one has documentation they really need one.
      However if one wants it simply as a riding toy, or to make others feel sorry for them, then applicable taxes must be paid.
        Who on earth would ever want one to make others feel sorry for them? It’s hard to even imagine such a thing. You sure have a miserable outlook on life. My sympathies.
        Proud NON-CASO
        Romans 15:13
        Deuteronomy 31:6
        Proverbs 28:1
          Bob: I know that rheumatoid arthritis is very crippling as a person gets older . I am sure that what you bought will help you getting around in that new state of the art garage that you said you were going to build earlier this year. I have some relation that live in Mexico New York that said you are going back into the used car business.
          John S.
            Thanks Bob. I've been thinking of a scooter for years, especially at the annual NSRA National in Louisville. There are thousands of cars there to look at; I'd love to see them all, but would need to walk probably 20 miles. I'm good for 3-4 miles nowadays, but that's pushing it, then time to get off my feet awhile. A scooter would make it possible, but I have begrugingly decided to just not see all the cars. Other than the NSRA, I seldom think of a scooter, so it'd be hard to justify the purchase. Each year there are more scooters at the NSRA, WalMart, SDC Meets, etc.. This year's NSRA looked like a bumper car convention, with some riders zooming around with a, "get out of my way" look on their faces toward walkers. So I found myself envying and resenting them at the same time. LOL
            Looks like you found an affordable trike that fits the bill nicely. Agree, technology continues to grow, and hopefully they'll get better and cheaper. I will keep trudging for now, and thank God I can still get by without one. I could use one for deer hunting though, but not sure how that would work out.
            When it comes to RA, age is not everything, and I've seen sufferers in their 40s. It can wax and wane also; my dad suffered in his 40s-60s as a mechanic; his hands would swell, and he took lots of aspirin. Now at 93, he is spry as a chicken, and seldom mentions RA. So in his case, he got better when he stopped having to turn wrenches. I also know an 83 year old fellow GoldWing rider who is getting new knees so he can continue to ride his bike!
            Thanks again, and hang in there. Enjoy that trike, and please keep use posted on the technology.
              The number of scooters we see at car shows out here has grown dramatically. At Back To The 50's (10,000+ cars on the 300+acre Minnesota State Fairgrounds) there are hundreds. Lots of Customs/Hotrods are rigged to carry them on a receiver hitch. And of course many people rent them there. I am a little disappointed that I don't see many of the scooters customized. When my time comes I'm hanging a bullet nose on the front of mine. I often tell people that I walk at least 5 miles a day at that event looking for all the Studebakers I can find. If you have ANY kind of problem from RA to as something as simple as a twisted ankle, a mobility scooter is the only way you can get to see enough cars to make it worthwhile. I saw several people in their 20's who'd had foot surgery of some sort on rented scooters and it made me glad they decided to get out and enjoy the event rather than sit at home.
              My idea to make money off of this is only half in jest. I tell people "It's a million dollar idea in 3 words: Mobility. Scooter. Dynamometer." The first year people will look at it and you'll have maybe a dozen participants. The next year you will have people lining up around the block and some of them will have 300 hp mobility scooters.
                You (and lots of others, it appears) are NOT alone: https://forums.aaca.org/topic/334870...ffic/#comments
                Here is someone else who also agrees: https://forums.aaca.org/topic/334986-hershey-phys-ed/
                  Thanks Joe Hall. I am about like you. I still get around reasonably well. I was on the fence about the trike because of what you said, there’s not many events I really need it for. In the end I decided I’m not not willing to compromise And miss out on what I want to see. I have absolutely no regrets. I have it put into storage for the winter now. It’s not like I’ll be trying to driving in the snow or something :-) But I’m looking forward to the big events I go to every year now with a renewed excitement. Probably next up will be spring Carlisle… Or maybe Mecum Kissimmee in January :-)
                  Proud NON-CASO
                  Romans 15:13
                  Deuteronomy 31:6
                  Proverbs 28:1
                    Just thought I’d share my mobility scooter. I went with the trike for the places that don’t allow this. Some places only allow electric powered. And have speed limits.
                    Proud NON-CASO
                    Romans 15:13
                    Deuteronomy 31:6
                    Proverbs 28:1
                      Now that's what I am talking about!
