Instrument light switch
  • Instrument light switch
    Looking for instrument light switch for 58 silver hawk coupe black handle.si no listing several other parts places out. Any ideas appreciated thanks
    Get a New 1544272 Black Head Light Switch and remove the Circuit Breaker, or not.
    You will have the full bright Instruments (the only setting that can be seen!) on both High and Low or none on Low depending on how you wire it because there would be no resister.
    If you are electrically inclined and Care to burn off a few Volts, you could could add one.
    [COLOR=#3399cc][B][FONT=Georgia][SIZE=20px]StudeRich [/SIZE][/FONT][/B][/COLOR]
    [SIZE=11px][FONT=Georgia][B][COLOR=#800080]Second Generation Stude Driver,
    SDC Member Since 1967[/COLOR][/B][/FONT][/SIZE]
      I might have a NOS one, but I'm on a trip and won't be back in Oregon for a couple more weeks. If you don't find one, send me a pm in October and I'll take a look for it. I bought it years ago thinking I could replace the handle and use it in my GT, but it's not the same switch.
        We have a N.O.S. instrument light switch in stock.
        Chris.
          switch
          great whats the price and how do we proceed bob
            Check with Chuck Collins.
            Lou Van Anne
            62 Champ
            64 R2 GT Hawk
            79 Avanti II
              no luck going with the headlight switch suggestion as they are available. Bob
                Email me at - chris@studeparts.com.au
                  what is the part number of the switch you need?
                    Bob, he needs a 1544274
                    Milt
                    1961 Hawk 4-speed
                    1967 Avanti
                    1961 Lark 2 door
                    1988 Avanti Convertible
                    [COLOR=#ff0000]Member of [B]SDC [/B]since 1973[/COLOR]
                      1544274 is the same switch as 1544273 but uses a different value resistor
                      It will dim the instrument lights different on low (11ohms instead of 5 ohms?)
                      1544274 was used on Hawks and 1544273 on sedans (1958 only)
                      I forgot if the
                      1544274 was 5 or 11 ohms.(different number of dash light bulbs)
                      1544273 is easier to find
                      Robert Kapteyn
                        What does this mean Bob?
                        If you are referring to my suggestion of using a Headlight Switch for a Instrument Light Switch, and the 1544272 IS available, WHY : : "No Luck"?
                          no luck with finding instrument switch easy to find headlight switch- found one in australia
                            put headlight switch in and instrument lights work job done.also put new front wiring harness (SI) and it works great. Last piece for electrical is rear harness which has been ordered.
                              Bob, we had the correct N.O.S. switch. I am having a hard time understanding your recent posts...........
